Hi !
another issue on the environement variable editor
I have environment variable on the application that have the same names on different services:
but when I use the same filter on a device env var editor, here is what I get:
there’s 2-ish issues here:
- there is only one variable instead of the 7 defined with this name at the application level
- the Application value is not the correct one, it’s the value of another of the env var with this name
I guess the second issue is only a result of the first one but I’d rather point it out in case it’s something else
thanks you all for fixing those issues quickly, it’s really appreciated
