Hello Guys,
I just started using resin.io and have some problems to copy files to the persistent folder.
If I understand it right I have at application runtime a folder ("/data") which keeps persistent data since it is at least a docker volume which will be mounted at startup.
So coping files at build phase wouldn’t work.
The app I try to run (home assistent) needs a config folder which contains all config-*.yaml files and keeps dynamic data from the app itself.
So the right place for the config folder is under /data
To update my configuration i copy the folder with my config-*.yaml-files
in the build phase to /usr/src/app/hass
and in the startup script I copy everything from /usr/src/app/hass to /data/hass.
But the config files in the /data folder stays in the old state. (timestamp, content not updated, file not copied)
has anybody some hints ?
modprobe v4l2_common &
if [ ! -d /data/hass ]; then
mkdir /data/hass
fi
cp -r /usr/src/app/hass /data/hass
echo "Content SOURCE"
ls -la /usr/src/app/hass
echo "Content DESTINATION"
ls -la /data/hass
echo "SYSTEM UP AND RUNNING ..."
#journalctl -xef
Output after startup:
18.01.18 10:43:00 (+0100) Content SOURCE
18.01.18 10:43:00 (+0100) total 36
18.01.18 10:43:00 (+0100) drwxrwxr-x 6 root root 4096 Jan 18 09:42 .
18.01.18 10:43:00 (+0100) drwxr-xr-x 4 root root 4096 Jan 18 09:41 ..
18.01.18 10:43:00 (+0100) -rw-rw-r-- 1 root root 456 Jan 18 09:42 appdaemon.yaml
18.01.18 10:43:00 (+0100) -rw-rw-r-- 1 root root 0 Jan 18 09:42 apps.yaml
18.01.18 10:43:00 (+0100) drwxrwxr-x 5 root root 4096 Jan 18 09:42 compiled
18.01.18 10:43:00 (+0100) -rw-rw-r-- 1 root root 1980 Jan 18 09:42 configuration.yaml
18.01.18 10:43:00 (+0100) drwxrwxr-x 5 root root 4096 Jan 18 09:42 custom_css
18.01.18 10:43:00 (+0100) drwxrwxr-x 11 root root 4096 Jan 18 09:42 custom_widgets
18.01.18 10:43:00 (+0100) -rw-rw-r-- 1 root root 0 Jan 18 09:42 customize.yaml
18.01.18 10:43:00 (+0100) drwxrwxr-x 2 root root 4096 Jan 18 09:42 dashboards
18.01.18 10:43:00 (+0100) -rw-rw-r-- 1 root root 270 Jan 18 09:42 secrets.yaml
18.01.18 10:43:00 (+0100) Content DESTINATION
18.01.18 10:43:00 (+0100) total 228
18.01.18 10:43:00 (+0100) drwxrwxr-x 8 root root 4096 Jan 18 09:42 .
18.01.18 10:43:00 (+0100) drwxr-xr-x 3 root root 4096 Jan 17 11:19 ..
18.01.18 10:43:00 (+0100) -rw-r--r-- 1 root root 6 Jan 17 11:19 .HA_VERSION
18.01.18 10:43:00 (+0100) -rw-r--r-- 1 root root 44 Jan 17 11:21 .uuid
18.01.18 10:43:00 (+0100) -rw-rw-r-- 1 root root 464 Jan 17 11:34 appdaemon.yaml
18.01.18 10:43:00 (+0100) -rw-rw-r-- 1 root root 0 Jan 17 11:34 apps.yaml
18.01.18 10:43:00 (+0100) drwxrwxr-x 5 root root 4096 Jan 17 11:14 compiled
18.01.18 10:43:00 (+0100) -rw-rw-r-- 1 root root 1980 Jan 17 11:34 configuration.yaml
18.01.18 10:43:00 (+0100) drwxrwxr-x 5 root root 4096 Jan 17 11:14 custom_css
18.01.18 10:43:00 (+0100) drwxrwxr-x 11 root root 4096 Jan 17 11:14 custom_widgets
18.01.18 10:43:00 (+0100) -rw-rw-r-- 1 root root 0 Jan 17 11:34 customize.yaml
18.01.18 10:43:00 (+0100) drwxrwxr-x 2 root root 4096 Jan 17 11:14 dashboards
18.01.18 10:43:00 (+0100) drwxr-xr-x 4 root root 4096 Jan 17 11:21 deps
18.01.18 10:43:00 (+0100) drwxr-xr-x 6 root root 4096 Jan 17 11:40 hass
18.01.18 10:43:00 (+0100) -rw-r--r-- 1 root root 383 Jan 18 09:19 home-assistant.log
18.01.18 10:43:00 (+0100) -rw-r--r-- 1 root root 169984 Jan 18 09:42 home-assistant_v2.db
18.01.18 10:43:00 (+0100) -rw-rw-r-- 1 root root 274 Jan 17 11:34 secrets.yaml
18.01.18 10:43:00 (+0100) SYSTEM UP AND RUNNING ...
