I suspect this isn’t an issue directly with the Balena CLI, but I’m hoping you can help me out.
I’ve got a balena application that builds just fine when pushed to balena, or emulated build on my OSX machine, but fails when run on our CI server.
The error message is:
DEBUG=1 balena build --arch armv7hf --deviceType raspberrypi3 --logs --emulated [Debug] Parsing input... [Debug] Loading project... [Debug] Resolving project... [Info] Compose file detected [Debug] Creating project... [Info] Building for armv7hf/raspberrypi3 [Build] Building services... [Build] jenkins Preparing... [Build] tinc Preparing... [Build] yoctopuce-virtualhub Preparing... [Info] Installing qemu for armv7hf emulation... [Info] Emulation is enabled [Debug] Found build tasks: [Debug] jenkins: build [./jenkins] [Debug] tinc: build [./tinc] [Debug] yoctopuce-virtualhub: build [./yoctopuce-virtualhub] [Debug] Resolving services with [raspberrypi3|armv7hf] [Debug] Found project types: [Debug] jenkins: Dockerfile.template [Debug] tinc: Dockerfile.template [Debug] yoctopuce-virtualhub: Dockerfile.template [Debug] Prepared tasks; building... [Build] Built 3 services in 0:10 [Error] Build failed Error: (HTTP code 500) server error - invalid reference format at /snapshot/balena-cli/node_modules/docker-modem/lib/modem.js:257:17 at IncomingMessage.<anonymous> (/snapshot/balena-cli/node_modules/docker-modem/lib/modem.js:284:9) at emitNone (events.js:91:20) at IncomingMessage.emit (events.js:185:7) at endReadableNT (_stream_readable.js:974:12) at _combinedTickCallback (internal/process/next_tick.js:80:11) at process._tickDomainCallback (internal/process/next_tick.js:128:9)
The balena CLI is invoked via a docker image:
FROM ubuntu:16.04 ENV BUILD_DEPS curl unzip docker.io ca-certificates RUN apt-get update && \ apt-get -y --no-install-recommends install ${BUILD_DEPS} && \ update-ca-certificates && \ apt-get clean && \ rm -rf /var/lib/apt/lists/* ENV VERSION v10.0.0 RUN curl https://github.com/balena-io/balena-cli/releases/download/${VERSION}/balena-cli-${VERSION}-linux-x64.zip \ --verbose -L -o /tmp/balena-cli-${VERSION}-linux-x64.zip && \ unzip /tmp/balena-cli-${VERSION}-linux-x64.zip -d /tmp/ && \ ln -s /tmp/balena-cli/balena /usr/bin/balena ENV DEBUG 1 CMD ["balena", "build", "--arch", "armv7hf", "--deviceType", "raspberrypi3", "--logs", "--emulated"]
The one thing that stands out to me is that because of the Docker-over-Docker deployment, the docker sock is running an older version of docker than the local client.
I also found some hints that the error message could be due to YAML issues, but I appears to be ok. The application code can be found here: https://dashboard.balena-cloud.com/apps/1384945/devices
