balena deploy is resulting in an error:
Request error: The request was unsuccessful
When the balena-cli is rerun with --debug mode we get the following:
UnauthorisedError: Request error: The request was unsuccessful
at wrapResponseError (/snapshot/balena-cli/node_modules/@balena/compose/dist/release/models.js:14:19)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async createRelease (/snapshot/balena-cli/node_modules/@balena/compose/dist/release/api.js:102:13)
at async Object.create (/snapshot/balena-cli/node_modules/@balena/compose/dist/release/api.js:15:21)
at async createRelease (/snapshot/balena-cli/build/utils/compose.js:75:40)
at async runSpinner (/snapshot/balena-cli/build/utils/compose_ts.js:831:16)
at async deployProject (/snapshot/balena-cli/build/utils/compose_ts.js:780:22)
at async DeployCmd.deployProject (/snapshot/balena-cli/build/commands/deploy/index.js:146:27)
at async DeployCmd.run (/snapshot/balena-cli/build/commands/deploy/index.js:50:25)
at async DeployCmd._run (/snapshot/balena-cli/node_modules/@oclif/core/lib/command.js:302:22)
at async Config.runCommand (/snapshot/balena-cli/node_modules/@oclif/core/lib/config/config.js:425:25)
at async run (/snapshot/balena-cli/node_modules/@oclif/core/lib/main.js:95:16)
at async /snapshot/balena-cli/build/app.js:81:13
at async Promise.all (index 2)
at async oclifRun (/snapshot/balena-cli/build/app.js:100:5)
at async Object.run (/snapshot/balena-cli/build/app.js:113:9)
This has just begun to happen with multiple SWEs this morning (I deployed successfully 9:09 AM EST).
