Hi all, I’m trying to write a .dmg file from Windows with balenaEtcher portable 1.5.100.
After start the write process, balenaEtcher stop and return this error:
gui.js:126777 {"stack":"Error [ERR_MULTIPLE_CALLBACK]: Callback called multiple times\n at Object.afterTransform (_stream_transform.js:87:31)\n at Object.asCallback (C:\\Users\\User\\AppData\\Local\\Temp\\1dgGE37HBe821nsVru5iqACH638\\resources\\app\\generated\\etcher.js:8778:13)","message":"Callback called multiple times","name":"Error","code":"ERR_MULTIPLE_CALLBACK","image":"image_file.dmg"}
console.<computed> @ gui.js:126777
logException @ gui.js:134145
flashImageToDrive @ gui.js:155658
async function (async)
flashImageToDrive @ gui.js:155647
handleWarningResponse @ gui.js:155696
done @ gui.js:155773
ba @ gui.js:103360
ja @ gui.js:103374
ka @ gui.js:103377
oa @ gui.js:103391
lc @ gui.js:104062
jc @ gui.js:104056
mc @ gui.js:104073
sc @ gui.js:104142
Ia @ gui.js:109372
Ma @ gui.js:103470
Rc @ gui.js:104408
id @ gui.js:104377
exports.unstable_runWithPriority @ gui.js:109701
cg @ gui.js:105569
Ga @ gui.js:109360
gd @ gui.js:104367
I have no problems writing the same .dmg file from macOS with the same balenaEtcher release.
Hi
Thanks for creating this issue - looks like a bug.
Can you please share the OS and Etcher versions for both the setups? This will help us debug this
Sorry I can’t share the .dmg file, it’s a company internal software.
I can say that it is a USB Device image created on macOS Catalina 10.15.5 from Disk Utility.
I clicked on the USB Device and select “Image from…”
Hello, what is the size of the image file ?
When creating the image file in Disk Utility, which format did you choose ?
For now Etcher will only work with “compressed” dmg files.
