Enable GPU on Container
Hi
The reason you are seeing this is that we had to pull the 2.44 version of the OS for all device types as we found a race condition in the boot process that would sometimes not allow the supervisor to start up correctly.
See a similar forum issue here - Can't update from 2.41.1 to 2.44.1
2.45.1 should work just like 2.44 for you, without the bug
