Appreciate a lot you help! i think it was my fault, i didn’t complite the configuration of mqtt device on EdgeX. So basically it come out what it was just a matter of compliance with the docker compose v3 format.
The only issue with restarts I encountered was with config-seed which I imagine would be some slight incompatibility with the balena supervisor.
If it restarts, for some reason it is facing an unexpected error and terminates the process, then supervisor attempts to restart the process and hence that behaviour. I honestly have no idea what the issue could be since all the services I used worked as expected. Please consult with EdgeX community in the slack channel for more in depth help from the developers of the platform.
I am so sorry that I can not offer any further assistance
Thank you for your analysis!
