I wanted to try out resin on an Intel development board based on Atom E3900. I started out with the pre-built NUC image in case it might work. Boots up okay, and ssh access is working but when I try to push a docker file it fails with the error stack copied below. Is this something simple, or should I go back to yocto and build my own resin image using meta-intel, meta-resin etc?
$ sudo resin local push resin.local --source .
rdt push failed. Error: Error while inspecting image myapp: Error: connect ECONNREFUSED 192.168.10.103:2375 Error: Error while inspecting image myapp: Error: connect ECONNREFUSED 192.168.10.103:2375
at /usr/local/lib/node_modules/resin-cli/node_modules/resin-sync/build/docker-utils.js:200:17
at tryCatcher (/usr/local/lib/node_modules/resin-cli/node_modules/bluebird/js/release/util.js:16:23)
at Promise._settlePromiseFromHandler (/usr/local/lib/node_modules/resin-cli/node_modules/bluebird/js/release/promise.js:512:31)
at Promise._settlePromise (/usr/local/lib/node_modules/resin-cli/node_modules/bluebird/js/release/promise.js:569:18)
at Promise._settlePromise0 (/usr/local/lib/node_modules/resin-cli/node_modules/bluebird/js/release/promise.js:614:10)
at Promise._settlePromises (/usr/local/lib/node_modules/resin-cli/node_modules/bluebird/js/release/promise.js:689:18)
at Async._drainQueue (/usr/local/lib/node_modules/resin-cli/node_modules/bluebird/js/release/async.js:133:16)
at Async._drainQueues (/usr/local/lib/node_modules/resin-cli/node_modules/bluebird/js/release/async.js:143:10)
at Immediate.Async.drainQueues (/usr/local/lib/node_modules/resin-cli/node_modules/bluebird/js/release/async.js:17:14)
at runCallback (timers.js:672:20)
at tryOnImmediate (timers.js:645:5)
at processImmediate [as _immediateCallback] (timers.js:617:5)
