I’m having a strange issue with my project. I’m getting the
The module xxx was compiled against a different Node.js version using NODE_MODULE_VERSION xx. This version of Node.js requires NODE_MODULE_VERSION yy
Error when deploying the project. Fwiw, it’s related to onoff library (or epoll), i.e
const Gpio = require('onoff').Gpio();
throws the error. If I ssh to the main process and run
npm install onoff
cd node_modules/onoff
npm install
node
> undefined
I can get rid of the error, but I can’t figure out what is going on with my Dockerfile and why I can’t get it working. (a part of) my dockerfile (it’s loosely based on balena-electronjs -template)
# I've tried with different versions of node 10.x and 12.x
FROM balenalib/raspberrypi3-debian-node:12.13-buster-build as build
# … some other install packages here (related to Electron)
# I had to install these separately to get some things working, but can't remember why... ;)
RUN JOBS=MAX npm install -g node-gyp
RUN JOBS=MAX npm install node-hid --build-from-source
RUN JOBS=MAX npm install \
--production --unsafe-perm \
&& npm cache clean --force \
&& rm -rf /tmp/* \
&& node_modules/.bin/electron-rebuild
# Move app to filesystem
COPY ./app ./
# create-react-app build
RUN JOBS=MAX npm run build
my package.json has
"electron": "^8.5.5", // I've tried with Electron 1.7, .... 9, 10, ... as well
"electron-rebuild": "^2.3.5",
"onoff": "^6.0.1",
I’ve also tried adding
RUN JOBS=MAX npm install onoff
RUN cd ./node_modules/onoff && npm run install
to my Dockerfile, but this didn’t get rid of the error (even though running these in command line worked).
Am I missing something obvious here?
