I am using ResinOS (2.0.6) for the Intel Edison, with the custom resinOS Docker (17.03.1-resin https://github.com/resin-os/docker/tree/17.03.1-resin).
I am running into some problems when using Docker Swarm. With the default build of ResinOS, docker services fail creating VXLAN interfaces. When I add VXLAN kernel support, my containers are not accessible through the exposed ports.
#How to reproduce this behavior
I’ve set up a minimal node.js server which listens on port 80.
Docker image: https://hub.docker.com/r/djb7/edison-expressjs-hello-world/
Code: https://github.com/djbb7/edison-expressjs-hello-world
My Intel Edison board has the IP 10.100.57.92
‘docker run’ works
If I ssh into the board and run the following, everything works as expected:
root@resin:~# docker run -d -p 80:80 djb7/edison-expressjs-hello-world
<container id>
root@resin:~# curl 10.100.57.92
Hello World, I'm a container running on resinOS
root@resin:~# docker stop $(docker ps -q)
<container id>
I can even access the web server from other computers in the same network.
‘docker service create’ fails
However, when I try to run the same image using swarm commands, the containers are not able to start due to an error creating vxlan interfaces:
root@resin:~# docker swarm init --advertise-addr 10.100.57.92
Swarm initialized: current note (pr22zwevmsb62zv6jfe1uxlmf) is now a manager.
root@resin:~# docker service create -p 80:80 djb7/edison-expressjs-hello-world
<service id>
root@resin:~# docker service ps relaxed_hypatia --no-trunc
ID NAME IMAGE NODE DESIRED STATE CURRENT STATE ERROR PORTS
1t2w7su0dm7r29yb3pxfffvpb relaxed_hypatia.1 djb7/edison-expressjs-hello-world:latest@sha256:4a7e9aad85d3fd2af6b60914a78890d50103d93d61d1e9d5956e41bd5e01deca resin Ready Preparing less than a second ago
w3cjzfjo1vodl24w7z0fco8kf \_ relaxed_hypatia.1 djb7/edison-expressjs-hello-world:latest@sha256:4a7e9aad85d3fd2af6b60914a78890d50103d93d61d1e9d5956e41bd5e01deca resin Shutdown Failed less than a second ago "starting container failed: subnet sandbox join failed for "10.255.0.0/16": error creating vxlan interface: operation not supported"
xaezmi61sla1noz3bev3kpj0l \_ relaxed_hypatia.1 djb7/edison-expressjs-hello-world:latest@sha256:4a7e9aad85d3fd2af6b60914a78890d50103d93d61d1e9d5956e41bd5e01deca resin Shutdown Failed 5 seconds ago "starting container failed: subnet sandbox join failed for "10.255.0.0/16": error creating vxlan interface: operation not supported"
ykvo1u7ar48o5nbdjv5swt6mh \_ relaxed_hypatia.1 djb7/edison-expressjs-hello-world:latest@sha256:4a7e9aad85d3fd2af6b60914a78890d50103d93d61d1e9d5956e41bd5e01deca resin Shutdown Failed 11 seconds ago "starting container failed: subnet sandbox join failed for "10.255.0.0/16": error creating vxlan interface: operation not supported"
olj25mbvcnqsfjypawbic1trb \_ relaxed_hypatia.1 djb7/edison-expressjs-hello-world:latest@sha256:4a7e9aad85d3fd2af6b60914a78890d50103d93d61d1e9d5956e41bd5e01deca resin Shutdown Failed 16 seconds ago "starting container failed: subnet sandbox join failed for "10.255.0.0/16": error creating vxlan interface: operation not supported"
txt9kuj0jzysj1ucazab0jkib \_ relaxed_hypatia.1 djb7/edison-expressjs-hello-world:latest@sha256:4a7e9aad85d3fd2af6b60914a78890d50103d93d61d1e9d5956e41bd5e01deca resin Shutdown Failed 21 seconds ago "starting container failed: subnet sandbox join failed for "10.255.0.0/16": error creating vxlan interface: operation not supported"
#Possible cause
I suspect that this might have something to do with the network configuration, even at kernel level. So I ran the check-config.sh script that comes with docker (https://github.com/resin-os/docker/blob/17.03.1-resin/contrib/check-config.sh). There are some kernel components which are missing (CONFIG_NETFILTER_XT_MATCH_IPVS, CONFIG_IP_NF_NAT, CONFIG_IPVLAN, CONFIG_VXLAN, CONFIG_DUMMY):
root@resin:/mnt/data/resin-data# ./check-config.sh
info: reading kernel config from /proc/config.gz ...
Generally Necessary:
- cgroup hierarchy: properly mounted [/sys/fs/cgroup]
- CONFIG_NAMESPACES: enabled
- CONFIG_NET_NS: enabled
- CONFIG_PID_NS: enabled
- CONFIG_IPC_NS: enabled
- CONFIG_UTS_NS: enabled
- CONFIG_CGROUPS: enabled
- CONFIG_CGROUP_CPUACCT: enabled
- CONFIG_CGROUP_DEVICE: enabled
- CONFIG_CGROUP_FREEZER: enabled
- CONFIG_CGROUP_SCHED: enabled
- CONFIG_CPUSETS: enabled
- CONFIG_MEMCG: enabled
- CONFIG_KEYS: enabled
- CONFIG_VETH: enabled
- CONFIG_BRIDGE: enabled
- CONFIG_BRIDGE_NETFILTER: enabled
- CONFIG_NF_NAT_IPV4: enabled
- CONFIG_IP_NF_FILTER: enabled
- CONFIG_IP_NF_TARGET_MASQUERADE: enabled (as module)
- CONFIG_NETFILTER_XT_MATCH_ADDRTYPE: enabled
- CONFIG_NETFILTER_XT_MATCH_CONNTRACK: enabled
- CONFIG_NETFILTER_XT_MATCH_IPVS: missing
- CONFIG_IP_NF_NAT: missing
- CONFIG_NF_NAT: enabled
- CONFIG_NF_NAT_NEEDED: enabled
- CONFIG_POSIX_MQUEUE: enabled
- CONFIG_DEVPTS_MULTIPLE_INSTANCES: enabled
Optional Features:
- CONFIG_USER_NS: missing
- CONFIG_SECCOMP: enabled
- CONFIG_CGROUP_PIDS: missing
- CONFIG_MEMCG_SWAP: missing
- CONFIG_MEMCG_SWAP_ENABLED: missing
- CONFIG_MEMCG_KMEM: missing
- CONFIG_RESOURCE_COUNTERS: enabled
- CONFIG_BLK_CGROUP: enabled
- CONFIG_BLK_DEV_THROTTLING: enabled
- CONFIG_IOSCHED_CFQ: enabled
- CONFIG_CFQ_GROUP_IOSCHED: missing
- CONFIG_CGROUP_PERF: enabled
- CONFIG_CGROUP_HUGETLB: missing
- CONFIG_NET_CLS_CGROUP: missing
- CONFIG_NETPRIO_CGROUP: missing
- CONFIG_CFS_BANDWIDTH: enabled
- CONFIG_FAIR_GROUP_SCHED: enabled
- CONFIG_RT_GROUP_SCHED: enabled
- CONFIG_IP_VS: missing
- CONFIG_IP_VS_NFCT: missing
- CONFIG_IP_VS_RR: missing
- CONFIG_EXT3_FS: enabled
- CONFIG_EXT3_FS_XATTR: enabled
- CONFIG_EXT3_FS_POSIX_ACL: enabled
- CONFIG_EXT3_FS_SECURITY: enabled
- CONFIG_EXT4_FS: enabled
- CONFIG_EXT4_FS_POSIX_ACL: enabled
- CONFIG_EXT4_FS_SECURITY: enabled
- Network Drivers:
- "overlay":
- CONFIG_VXLAN: missing
Optional (for encrypted networks):
- CONFIG_CRYPTO: enabled
- CONFIG_CRYPTO_AEAD: enabled
- CONFIG_CRYPTO_GCM: missing
- CONFIG_CRYPTO_SEQIV: enabled
- CONFIG_CRYPTO_GHASH: missing
- CONFIG_XFRM: enabled
- CONFIG_XFRM_USER: enabled
- CONFIG_XFRM_ALGO: enabled
- CONFIG_INET_ESP: enabled
- CONFIG_INET_XFRM_MODE_TRANSPORT: enabled
- "ipvlan":
- CONFIG_IPVLAN: missing
- "macvlan":
- CONFIG_MACVLAN: enabled
- CONFIG_DUMMY: missing
- Storage Drivers:
- "aufs":
- CONFIG_AUFS_FS: enabled
- "btrfs":
- CONFIG_BTRFS_FS: missing
- CONFIG_BTRFS_FS_POSIX_ACL: missing
- "devicemapper":
- CONFIG_BLK_DEV_DM: missing
- CONFIG_DM_THIN_PROVISIONING: missing
- "overlay":
- CONFIG_OVERLAY_FS: missing
- "zfs":
- /dev/zfs: missing
- zfs command: missing
- zpool command: missing
Limits:
- /proc/sys/kernel/keys/root_maxkeys: 1000000
#Attempted solution
I recompiled resinOS with the missing CONFIG_* components. I did so by adding them to layers/meta-resin-edison/recipes-kernel/linux/files/defconfig
as well as adding them to RESIN_CONFIGS_DEPS[docker] in layers/meta-resin/meta-resin-common/classes/kernel-resin.bbclass
. After re-flashing I run the check-config.sh script:
Optional Features:
- CONFIG_IP_VS: enabled (as module)
- Network Drivers:
- "overlay":
- CONFIG_VXLAN: enabled (as module)
Optional (for secure networks):
- "ipvlan":
- "macvlan":
- CONFIG_DUMMY: enabled
- Storage Drivers:
- "aufs":
- "btrfs":
- "devicemapper":
- "overlay":
- "zfs":
- /dev/zfs: missing
Limits:
As can be seen the ‘Generally Necessary’ configs are present, as well as CONFIG_VXLAN. Somehow CONFIG_IPVLAN is still missing, even if it is marked in the defconfig
with a =y
, and in the kernel-resin.bbclass
recipe. I attempt to run my simple hello world server again:
root@resin:/mnt/data/resin-data# docker swarm init —advertise-addr 10.100.57.92
Swarm initialized: current node (5qf4hvfpt9o8ss8tjr9ul4xvo) is now a manager.
To add a worker to this swarm, run the following command:
docker swarm join \
—token SWMTKN-1-0ki53aas597wxdnp9w54wdcwpb9iiujog63vr1hjrn7qisuq3e-2yherw73m9a9lh6cuyizcj8dx \
10.100.57.92:2377
To add a manager to this swarm, run 'docker swarm join-token manager' and follow the instructions.
root@resin:/mnt/data/resin-data# docker service create -p 80:80 djb7/edison-expressjs-hello-world
441w76skiv8bgr2f1xiwxaphb
root@resin:/mnt/data/resin-data# docker service ls
ID NAME MODE REPLICAS IMAGE
441w76skiv8b youthful_mclean replicated 1/1 djb7/edison-expressjs-hello-world:latest
root@resin:/mnt/data/resin-data# docker service inspect youthful_mclean --pretty
Service Mode: Replicated
Replicas: 1
Placement:
UpdateConfig:
Parallelism: 1
On failure: pause
Max failure ratio: 0
ContainerSpec:
Image: djb7/edison-expressjs-hello-world:latest@sha256:4a7e9aad85d3fd2af6b60914a78890d50103d93d61d1e9d5956e41bd5e01deca
Resources:
Endpoint Mode: vip
Ports:
PublishedPort 80
Protocol = tcp
TargetPort = 80
root@resin:/mnt/data/resin-data# curl http://10.100.57.92
curl: (7) Failed to connect to 10.100.57.92 port 80: Connection refused
As can be seen this time the service is running, but it’s simply not possible to access it from outside the container. Sorry for the quite lengthy post, I tried to be as explicit as possible.
Maybe I am missing something? Is there a way to make services accessible to the outside world by exposing ports? Hope you can help me solve this.
Edit: 1) CONFIG_IP_NF_NAT is also not being loaded, despite the fact that it’s present in the kernel-resin.bbclass. The latest check-config.sh script, available from the moby/moby repository lists it as generally necessary.
2) If I don’t specify any published ports when I create the service, I am able to ping from inside the service container to the outside network (e.g. google.com). If I specify ports, then ping doesn’t work.
