docker-compose - exec format error
Hey there!
I’m running raspbian os on a raspberry pi 3 and following the openBalena documentation I came across the following error:
how to proceed?
Hey @RonaldGuilhermePDS - the error you are seeing is because you try to install openBalena - which is for x64 only - on a Raspberry Pi 3 - which is ARM architecture. openBalena needs to be installed on an Ubuntu 18.04 x64 server as detailed in the Getting started guide: openBalena - Home - it will not run on an Raspberry Pi 3.
Cheers,
Nico
