I’m developing an application that spans multiple device types / architectures.
I’m using a Dockerfile.template like this:
FROM wlisac/%%BALENA_MACHINE_NAME%%-swift:5.0
# do stuff
This works great with BalenaCloud, but one downside to this approach is that this template won’t build locally via docker build:
$ docker build -f Dockerfile.template .
Step 1/8 : FROM wlisac/%%BALENA_MACHINE_NAME%%-swift:5.0
invalid reference format: repository name must be lowercase
A workaround is to use a build-arg in the Dockerfile.template like this:
ARG BASE_IMAGE=wlisac/%%BALENA_MACHINE_NAME%%-swift:5.0
FROM $BASE_IMAGE
# do stuff
And then you can build the Dockerfile locally like this:
$ docker build -f Dockerfile.template --build-arg BASE_IMAGE=wlisac/raspberrypi3-swift:5.0 .
This is a decent workaround, but I’m wondering if Balena would consider sending build args for BALENA_MACHINE_NAME and other variables that are often used in templates when building via Balena.
This would allow a plain Dockerfile like this to work locally and via BalenaCloud without using a template:
Dockerfile
ARG BALENA_MACHINE_NAME=raspberrypi3
FROM wlisac/$BALENA_MACHINE_NAME-swift:5.0
# do stuff
I’m not sure of the origin of Balena’s Dockerfile.template, but it’s possible that Allow ARG in FROM makes templating less necessary.
Would love to know what others think of this idea.
Cheers,
Will
