Hello folks.
Main objective
Get device to synchronize time on a restrictive network with only NTP access.
I’m attempting to disable the HTTPS time synchronization (timesync-https.service) on my Balena device to prevent it from performing time sync over HTTPS, as my network environment causes this process to fail.
I only have access to NTP server and timesync-https is blocking chrony from running.
I’m performing test on latest build 5.1.20
Problem Description:
Despite following the Balena documentation and modifying my config.json to set the connectivity check URI to null and the interval to "0", my device still attempts to synchronize time using the timesync-https.service.
As indicated by systemctl status timesync-https showing the service in an activating state.
Configuration Attempted:
Here is the relevant section of my config.json:
"os": {
"network": {
"connectivity": {
"uri": null,
"interval": "0"
- Updated
config.jsonas described above and rebooted the device. - Checked the service status with
systemctl status timesync-https, which showed that the service is still attempting to start. - Performed
nmcli networking connectivity checkandnmcli general status, both indicating that the network connectivity isfull.
Have I misunderstood something? This should be possible since version v3.2.12.
Any advice or insights would be greatly appreciated.
Related topic with excellent information from nebbles.
