Hi, I set up a device that is powered over ethernet but not connected to wired network, instead I configured it to connect to Wi-Fi as it was going to be a big job to run a network cable for it.
The device is outside and the Wi-Fi turned out to be unreliable as a result, so I have now installed the network cable and it is connected to wired ethernet. I have removed the device’s access to the Wi-Fi network and as a result it is broadcasting the BalenaWiFi SSID to aid connecting to a new network.
The problem with this device is it is in a sealed box mounted at the top of a tower and I can’t easily get to the device physically so I am not able to re-flash balenaOS with the Wi-Fi disabled. Is there any way I can remotely disable the Wi-Fi on this device so that it does not try to connect to the Wi-Fi network and then end up broadcasting the BalenaWiFi?
It includes a container called wifi-connect which basically if your device is configured for connection to a Wi-Fi network and it fails to connect after a certain amount of time, it starts up a hotspot called BalenaWiFi to which you can connect and then input details of a different Wi-Fi network to connect to. Once you hit connect it will stop the hotspot and connect to the network you have configured.
Ah, okay, so you’re a user of the ads-b application, not something you’re developing yourself. I think you’ll need to take it up with the maintainers of the app. But based on the readme I wouldn’t be too hopeful:
Please note: Due to how these services are integrated, it’s not currently possible to disable the wifi-connect and kiosk services.
