Is there an easy way to disable USB autosuspend within Balena OS?
i.e. this file I would need to set to -1
/sys/module/usbcore/parameters/autosuspend
Hey there, balenaOS does not have a dedicated switch for that but the file should be writable from a container so you can do that during the startup of the application at runtime.
There are two requirements:
io.balena.features.sysfs label as described in docker-compose.yml fields - Balena Documentation
Let us know if you’re able to get this working!
