Hey there
I recently tried to use a DHT22 temperature and humidity sensor using a RPi3 and Resin OS 2.13.6+rev1.
I tried various method to get the sensor to work:
I tried to add the module
Adafruit-DHT==1.3.4in requirements.txt, but when I tried to push the code to the device, it gives me this error:
Could not detect if running on the Raspberry Pi or Beaglebone Black. If this failure is unexpected, you can run again with --force-pi or --force-bbb parameter to force using the Raspberry Pi or Beaglebone Black respectively.' -
Then I tried to install the module in the dockerfile:
cd /tmp/ && git clone https://github.com/adafruit/Adafruit_Python_DHT.git && \
cd Adafruit_Python_DHT && python3 setup.py install &&
which successfully deployed the code to the application but in my logger python threw an error:
ImportError: No module named 'Adafruit_DHT' and when I try to install it in the container via the terminal I get the error:
importError: cannot import name 'Raspberry_Pi_2_Driver'
after a lot of trial and error I came up with this solution to install and import the package on the device:
def install(package):
subprocess.call([sys.executable, "-m", "pip", "install", package])
try:
install('Adafruit-DHT==1.3.4')
import Adafruit_DHT
except:
raise ValueError('Failed to import and install Adafruit.')
I couldn’t find any resources online to assist me with this so I am adding it here for anyone struggling wwith this in the future.
