Open balena server OS
Ubuntu 16.04
Development OS
Linux Mint 19.3
Device image
balena-cloud-intel-nuc-2.50.1+rev1-dev-v11.4.10
server vpn container log
Jun 17 12:10:07 6ccb5498a775 haproxy[221]: Routing 95.232.37.146:64344@tcp-443 to vpn-cluster/vpn1:54358 [C:1/1 Q:0/0 T:1/0]
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: TCP connection established with [AF_INET]127.0.0.1:54358
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 peer info: IV_VER=2.4.7
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 peer info: IV_PLAT=linux
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 peer info: IV_PROTO=2
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 peer info: IV_NCP=2
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 peer info: IV_LZ4=1
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 peer info: IV_LZ4v2=1
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 peer info: IV_LZO=1
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 peer info: IV_COMP_STUB=1
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 peer info: IV_COMP_STUBv2=1
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 peer info: IV_TCPNL=1
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: info: AUTH FAIL: API Authentication failed for c532c099e4dde63835738982e0d4e401
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: ::ffff:127.0.0.1 - - [17/Jun/2020:12:10:07 +0000] "POST /api/v1/auth/ HTTP/1.1" 401 12 "-" "curl/7.52.1"
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 WARNING: Failed running command (--auth-user-pass-verify): external program exited with error status: 1
Jun 17 12:10:07 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 TLS Auth Error: Auth Username/Password verification failed for peer
Jun 17 12:10:08 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384
Jun 17 12:10:08 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 Peer Connection Initiated with [AF_INET]127.0.0.1:54358
Jun 17 12:10:09 6ccb5498a775 balena-vpn-api[1487]: 127.0.0.1:54358 Connection reset, restarting [0]
Device log
The device logs are the same of issue Failing to add device
Thanks in advance for the support!!
