My Raspberry Pi 1 is in a strange state. I can manually power cycle it, it comes up online on the Resin dashboard, but the service doesn’t start running. Also the restart and reboot buttons gives an error:
Request error: tunneling socket could not be established, cause=socket hang up
The public URL also doesn’t work.
I can however still SSH into the host OS where I can run commands, like this:
root@55ef69e:~# journalctl -fn 100 -u resin-supervisor
-- Logs begin at Tue 2018-02-27 17:41:30 UTC. --
Jul 18 14:07:02 55ef69e systemd[1]: Starting Resin supervisor...
Jul 18 14:07:03 55ef69e balena[1049]: resin_supervisor
Jul 18 14:07:03 55ef69e systemd[1]: Started Resin supervisor.
Jul 18 14:07:40 55ef69e healthdog[1056]: [56B blob data]
Jul 18 14:07:40 55ef69e healthdog[1056]: [59B blob data]
Jul 18 14:07:45 55ef69e healthdog[1056]: [87B blob data]
Jul 18 14:07:45 55ef69e healthdog[1056]: [79B blob data]
Jul 18 14:07:52 55ef69e healthdog[1056]: 2018/07/18 14:07:52 main.go:41: Resin Go Supervisor starting
Jul 18 14:07:52 55ef69e healthdog[1056]: 2018/07/18 14:07:52 main.go:32: Starting HTTP server on /var/run/resin/gosuper.sock
Jul 18 14:09:33 55ef69e healthdog[1056]: [2018-07-18T14:09:33.348Z] Event: Supervisor start {}
Jul 18 14:09:33 55ef69e healthdog[1056]: [2018-07-18T14:09:33.751Z] Starting pubnub logger
Jul 18 14:09:44 55ef69e healthdog[1056]: [2018-07-18T14:09:44.211Z] Unhandled rejection TypeError:Cannot read property 'slice' of null
Jul 18 14:09:44 55ef69e healthdog[1056]: at t (/usr/src/app/dist/app.js:1:730120)
Jul 18 14:09:44 55ef69e healthdog[1056]: at Zt (/usr/src/app/dist/app.js:1:8073)
Jul 18 14:09:44 55ef69e healthdog[1056]: at Function.Ja [as map] (/usr/src/app/dist/app.js:1:42834)
Jul 18 14:09:44 55ef69e healthdog[1056]: at Object.t.envArrayToObject (/usr/src/app/dist/app.js:1:730145)
Jul 18 14:09:44 55ef69e healthdog[1056]: at e.exports.e.fromContainer (/usr/src/app/dist/app.js:1:744249)
Jul 18 14:09:44 55ef69e healthdog[1056]: at u (/usr/src/app/dist/app.js:1:75045)
Jul 18 14:09:44 55ef69e healthdog[1056]: at A._settlePromiseFromHandler (/usr/src/app/dist/app.js:1:783032)
Jul 18 14:09:44 55ef69e healthdog[1056]: at A._settlePromise (/usr/src/app/dist/app.js:1:783832)
Jul 18 14:09:44 55ef69e healthdog[1056]: at A._settlePromise0 (/usr/src/app/dist/app.js:1:784531)
Jul 18 14:09:44 55ef69e healthdog[1056]: at A._settlePromises (/usr/src/app/dist/app.js:1:785858)
Jul 18 14:09:44 55ef69e healthdog[1056]: at s._drainQueue (/usr/src/app/dist/app.js:1:788861)
Jul 18 14:09:44 55ef69e healthdog[1056]: at s._drainQueues (/usr/src/app/dist/app.js:1:788922)
Jul 18 14:09:44 55ef69e healthdog[1056]: at Immediate.drainQueues (/usr/src/app/dist/app.js:1:787133)
Jul 18 14:09:44 55ef69e healthdog[1056]: at runCallback (timers.js:574:20)
Jul 18 14:09:44 55ef69e healthdog[1056]: at tryOnImmediate (timers.js:554:5)
Jul 18 14:09:44 55ef69e healthdog[1056]: at processImmediate [as _immediateCallback] (timers.js:533:5)
Running ip addr gives me this:
root@55ef69e:~# ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel qlen 1000
link/ether b8:27:eb:42:91:9b brd ff:ff:ff:ff:ff:ff
inet 192.168.8.101/24 brd 192.168.8.255 scope global dynamic eth0
valid_lft 85653sec preferred_lft 85653sec
inet6 fe80::a8be:f323:acb8:7f62/64 scope link
3: resin-dns: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue qlen 1000
link/ether 1a:2e:76:b0:51:f4 brd ff:ff:ff:ff:ff:ff
inet 10.114.102.1/24 scope global resin-dns
inet6 fe80::182e:76ff:feb0:51f4/64 scope link
4: resin-vpn: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc fq_codel qlen 100
link/[65534]
inet 10.240.37.153 peer 52.4.252.97/32 scope global resin-vpn
inet6 fe80::984e:ffff:5915:65a3/64 scope link
5: balena0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue
link/ether 02:42:b8:1c:17:55 brd ff:ff:ff:ff:ff:ff
inet 10.114.101.1/24 scope global balena0
6: supervisor0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue
link/ether 02:42:60:4f:f1:0a brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 scope global supervisor0
7: br-b068b6a8c920: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue
link/ether 02:42:1a:6e:24:e3 brd ff:ff:ff:ff:ff:ff
inet 172.18.0.1/16 scope global br-b068b6a8c920
The supervisor does indeed seem unhealthy:
root@55ef69e:~# balena ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
08bc27ea0b56 2b09725d2576 "/usr/bin/entry.sh..." About an hour ago Up20 seconds main_370772_539856
eef64d9001fd resin/rpi-supervisor:v7.1.14 "/sbin/init" 2 months ago Up16 minutes (unhealthy) resin_supervisor
Does anyone have a suggestion how I can get the Pi to work normally again. It is installed at a remote location, so reflashing the SD card is not an option.
