I tried to update my open balena container. After the upgrade to that version:
OPENBALENA_API_VERSION_TAG=v0.31.0
OPENBALENA_DB_VERSION_TAG=v3.0.1
OPENBALENA_REGISTRY_VERSION_TAG=v2.11.3
OPENBALENA_S3_VERSION_TAG=v2.8.5
OPENBALENA_VPN_VERSION_TAG=v9.2.0
OPENBALENA_MDNS_PUBLISHER_VERSION_TAG=v1.6.2
i get this error:
db_1_4311d5a08a74 | 2019-09-11 12:21:38.455 UTC [31] ERROR: column device.device type does not exist at character 172
db_1_4311d5a08a74 | 2019-09-11 12:21:38.455 UTC [31] HINT: Perhaps you meant to reference the column "device.device name" or the column "device.is-device type".
db_1_4311d5a08a74 | 2019-09-11 12:21:38.455 UTC [31] STATEMENT: SELECT "device"."id"
db_1_4311d5a08a74 | FROM (
db_1_4311d5a08a74 | SELECT "device"."created at", "device"."id", "device"."actor", "device"."uuid", "device"."local id", "device"."device name", "device"."note", "device"."device type", "device"."is of-device type table", "device"."belongs to-application", "device"."is online", "device"."last connectivity event", "device"."is connected to vpn", "device"."last vpn event", "device"."is locked until-date", "device"."logs channel", "device"."public address", "device"."vpn address", "device"."ip address", "device"."is on-commit", "device"."download progress", "device"."status", "device"."os version", "device"."os variant", "device"."supervisor version", "device"."provisioning progress", "device"."provisioning state", "device"."api port", "device"."api secret", "device"."is managed by-service instance", "device"."should be running-release", "device"."is managed by-device"
db_1_4311d5a08a74 | FROM "device"
db_1_4311d5a08a74 | WHERE ("device"."actor" = $1
db_1_4311d5a08a74 | OR EXISTS (
db_1_4311d5a08a74 | SELECT 1
db_1_4311d5a08a74 | FROM "application" AS "device.belongs to-application"
db_1_4311d5a08a74 | WHERE "device"."belongs to-application" = "device.belongs to-application"."id"
db_1_4311d5a08a74 | AND EXISTS (
db_1_4311d5a08a74 | FROM "application" AS "device.belongs to-application.depends on-application"
db_1_4311d5a08a74 | WHERE "device.belongs to-application"."depends on-application" = "device.belongs to-application.depends on-application"."id"
db_1_4311d5a08a74 | FROM "device" AS "dev.belongs to-application.depends on-application.owns-device"
db_1_4311d5a08a74 | WHERE "device.belongs to-application.depends on-application"."id" = "dev.belongs to-application.depends on-application.owns-device"."belongs to-application"
db_1_4311d5a08a74 | AND "dev.belongs to-application.depends on-application.owns-device"."actor" = $1
db_1_4311d5a08a74 | )
db_1_4311d5a08a74 | ))
db_1_4311d5a08a74 | ) AS "device"
db_1_4311d5a08a74 | WHERE "device"."uuid" = $2
Can somebody help?
good! What an exciting news. I will continue to follow.
