Shuuri
February 14, 2020, 8:03am
1
I had a container that builds from x11-window-manager (https://github.com/balena-io-playground/x11-window-manager/blob/master/Dockerfile.raspberrypi3 ).
The container has chromium-browser rpi-chromium-mods installed. However, I can’t run the chromium-browser.
Got error message as below:
Thus, I created a user pi and added the pi user to group audio, video, input, tty However, I still obtained root user when the desktop is up. How to change it to load as pi user so I can use chromium.
srlowe
February 14, 2020, 9:23am
2
Hello, Please could you post your updated Dockerfile?
Shuuri
February 17, 2020, 12:39am
4
Hi @srlowe ,
Here is my updated Dockerfile.
I added vncserver, raspbian chromium (rpi-chromium-mods) with libgles2 and lxterminal.
I am using docker-compose instead of docker run.
Then added user pi and add to groups as in the Dockerfile screenshot.
jviotti
February 17, 2020, 12:45pm
5
Hey there! Have you tried using the USER Dockerfile keyword? (https://docs.docker.com/engine/reference/builder/#user ). That should affect all the subsequent commands and make them run as that user
Shuuri
February 17, 2020, 4:31pm
7
Hi @jviotti ,
Yes, I did.
However, startx command on the start.sh (https://github.com/balena-io-playground/x11-window-manager/blob/master/start.sh ) not allowed the Pi user to execute the command.
Ended up with the error, as shown
My docker-compose is as shown:
Updated Dockerfile:
Hi
I did some search and I’ve found this workaround mentioned in a few places: try installing package xserver-xorg-legacy as well
If that does not work, can you please share the content of file /home/pi/.local/share/xorg/Xorg.0.log: it’s mentioned in the error message
Best regards
federico
Alternatively, you can try starting chromium as root with --no-sandbox, as suggested in your first error message: unless you need chromium sandbox support, it should just work
Shuuri
February 18, 2020, 12:31am
12
Yes, the --no-sandbox is working but I preferred to run Chromium without the --no-sandbox flag as security issue also part of my concern.
Thanks & Best Regards,
Shuuri
Shuuri
February 18, 2020, 12:37am
13
I will try on the xserver-xorg-legacy package.
I just wander if there is other way like through the lightdm window manager as I checked official Raspbian and found out that the packages is not installed but it can run as pi user.
Hi Shuuri
Indeed running without the no-sandbox option would be better. Let us know if xserver-xorg-legacy fixes the issue
