Corviont - offline maps + routing + geocoding as a local Docker stack for edge devices
Hi balena folks - sharing a project I’ve been building and would love feedback on whether this is useful in real balena deployments.
Corviont is a self-hosted/offline maps stack for edge/on-prem setups:
  • vector tiles (PMTiles) + MapLibre UI
  • offline routing (Valhalla)
  • offline geocoding + reverse (SQLite index)
  • single gateway (Nginx) on one port
Goal: after the initial images/data are present, it runs fully locally (no external API calls).
Try it:
I also published hardware footprint + p95 latency benchmarks across multiple regions:
Questions for the community:
  1. Do you ever need maps/routing/search to work fully offline on your devices (field crews, kiosks, gateways, secured sites)?
  2. If yes - what’s usually the production blocker: data updates, auth/RBAC, custom overlays/POIs, address quality, storage/RAM constraints?
  3. Would a balenaHub-ready ”Deploy with balena” version be useful, or is docker-compose enough?
