Hey all, I’m trying to use balena build
to build a project. My use case is that I need to make local edits to the container before it’s pushed/deployed to balena cloud. I had some issues creating a working container based off of the balenalib/ base images using plain docker, so figured I would try yo use balena build instead.
My docker-compose.yml
file is as follows:
version: "2"
services:
ignition:
build: ./myproject
ports:
- "9099:9099"
While my Dockerfile
(of course under ./myproject/
) is as follows:
FROM balenalib/amd64-ubuntu:jammy-run
RUN apt-get update && \
apt-get install -y unzip
COPY ~/myprojectsrc/linux/amd64/myproject.zip ./myproject.zip
RUN unzip myproject.zip -d myproject
RUN chmod +x ./myproject/*.sh
CMD ["/bin/bash", "/myproject/myproject.sh"]
balena build
doesn’t complain initially and downloads and installs the unzip util. However, after that the build errors out with the following message:
[Error] Build failed.
COPY failed: file not found in build context or excluded by .dockerignore: stat ~/myprojectsrc/linux/amd64/myproject.zip: file does not exist
Not sure what exactly is going on - the COPY works perfectly running under normal Docker. And when I move the myproject.zip
file to the Dockerfile’s local directory (./myproject
), I instead get:
Array buffer allocation failed
