Hi @rlev -
I found the Makefile in some random corner of the web… it does show that I can redistribute it as long as I keep the copyright info, so I feel OK about sharing it. I can’t remember where I found it though.
I would post the complete bundle up on my GitHub, but I am unsure of the legality of redistributing the firmware files. You can get them from here - https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/rsi
If you’re interested in what the whole thing looked like, here’s what I believe is the final working code. I was not able to use Balena in the end of this project because of the kernel needing GPIO, (which has been included now!). I was only working on this for a short term contract project between jobs.
- Taking the
kernel-module-build
example, add these directories:rsi/
,mac80211/
,firmware/
. - Copy the contents of the RSI kernel source into
rsi/
, replacing the Makefile with this one Makefile.log (4.4 KB) (renamed with a.log
to get around the forum file filter). - Copy the compiled
mac80211.ko
file from the existing kernel into a directory inside the container so that I could initialize it from this run script. There is probably a better way. - Copy the RPS files to
firmware/
. - Use the following Docker template and run script.
Dockerfile.template:
FROM balenalib/%%RESIN_MACHINE_NAME%%-debian
RUN apt-get update && apt-get install -y curl wget build-essential libelf-dev awscli bc flex libssl-dev python bison
COPY . /usr/src/app
WORKDIR /usr/src/app
ENV VERSION '2.36.0+rev2.prod'
RUN ./build.sh %%RESIN_MACHINE_NAME%% $VERSION rsi
CMD ./run.sh
run.sh:
#!/bin/bash
OS_VERSION=$(echo $RESIN_HOST_OS_VERSION | cut -d " " -f 2)
echo "OS Version is $OS_VERSION"
mkdir -p /lib/firmware/rsi
cp firmware/* /lib/firmware/rsi/
insmod mac80211/mac80211.ko
mod_dir="rsi_${RESIN_DEVICE_TYPE}_${OS_VERSION}*"
insmod $mod_dir/rsi_91x.ko
insmod $mod_dir/rsi_sdio.ko
lsmod | grep rsi
while true; do
sleep 60
done
Hope this is of value to you!
