Hello!
We have recently moved our network shares to an AWS FSx file server and ever since then I have been unable to mount it using cifs on our balena devices.
Trying a mount with:
mkdir /mnt/my-share
mount -t cifs -o username=test //<server_address>/<share_name>/ /mnt/my-share/
Always returns a mount error(2): No such file or directory. With the following kernel messages:
[347779.475853] CIFS: Attempting to mount //<server_address>/<share_name>/
[347779.546190] CIFS: VFS: BAD_NETWORK_NAME: \\<server_address>\<share_name>
[347779.564867] CIFS: VFS: cifs_mount failed w/return code = -2
These might sound like a network issue but I am actually able to mount exactly the same share when I try some userspace tools like smbnetfs or smbclient.
Previously, when we were still working with our old self-hosted SMB share, we were able to make the mount work by explicitly specifying the SMB dialect with vers=1.0, however, that does not work anymore since AWS FSx doesn’t support SMB1.
The device in question is a generic Generic x86_64 machine running on balenaOS 2.95.12+rev1 and supervisor version 12.11.38
I had the suspicion that the used cifs kernel module doesnt support SMB3 since I cant see any SMB3 or SMB211 kernel config flags when running:
> zcat /proc/config.gz | grep CIFS
CONFIG_CIFS=y
# CONFIG_CIFS_STATS2 is not set
CONFIG_CIFS_ALLOW_INSECURE_LEGACY=y
CONFIG_CIFS_WEAK_PW_HASH=y
CONFIG_CIFS_UPCALL=y
CONFIG_CIFS_XATTR=y
CONFIG_CIFS_POSIX=y
CONFIG_CIFS_DEBUG=y
# CONFIG_CIFS_DEBUG2 is not set
# CONFIG_CIFS_DEBUG_DUMP_KEYS is not set
CONFIG_CIFS_DFS_UPCALL=y
# CONFIG_CIFS_ROOT is not set
Unfortunately, an out-of-tree module installation does not seem to be an option since cifs is a built-in module now and as I am not even sure if I am following the right track I also didnt want to try and rebuild the kernel from source (also because I have no idea how linux and especially this yocto kernel that balena uses actually work
Has anyone else already encountered this problem and can suggest any workarounds?
Any idea is much appreciated!
Best,
Atabey
PS: I cant use smbclient for my application since it doesnt allow to actually mount a network share and smbnetfs would in theory do the trick but unfortunately it runs extremely unstable and I sometimes need to retry transferring files for hours until they eventually make their way onto the network share.
