Hello
Is it possible to change an env variable of a container without using dashboard? My device has no internet access so I need to change 1 env variable in a container from HostOS which was defined previously from dashboard.
Is this possible with Balena?
Thanks in advance,
Hello @berkayg
Could you please tell us more details on how would you like to change the environment variable if the device has no Internet access?
Could you please share us more about the use case here?
