Can't push into balena hub (service.ipc which references service:${serviceName} is not supported)
I am trying to deploy a release to balenahub via git push, but the balena builder is rejecting the push with the following error:
Enumerating objects: 51, done.
Counting objects: 100% (51/51), done.
Delta compression using up to 16 threads
Compressing objects: 100% (51/51), done.
Writing objects: 100% (51/51), 3.42 MiB | 4.10 MiB/s, done.
Total 51 (delta 16), reused 0 (delta 0), pack-reused 0
[Error]    Could not parse compose file
[Error]      service.ipc which references service:${serviceName} is not supported
[Error]    Not deploying release.
The issue is that my docker-compose.yml does not use cross-service IPC. It only contains a single service and explicitly uses ipc: host.
From docker-compose.yml
   ipc: host
Yesterday, prior to the release I could push this to my testing fleet without errors, today I can’t even push the same code to the testing fleet.
Is there something I’m missing or have been changes from your side?
If needed, I can provide the full docker-compose.yml file.
Aitor Nieto
Owasys S.L.
Just following up - there was a short period when this issue was occurring with the builder but it should be corrected now. Let us know if that’s not the case for you.
