Firat
September 13, 2023, 10:22am
1
I’m trying to retrieve information from my device which is connected to /dev/ttyACM0, but the feedback is completely empty. Here is my little script:
for port in /dev/ttyACM*; do
echo "port name : $port"
echo "manufacturer : $(udevadm info -q property -n $port | grep ID_VENDOR)"
echo "Id vendor : $(udevadm info -q property -n $port | grep ID_VENDOR_ID)"
echo "ID product : $(udevadm info -q property -n $port | grep ID_MODEL_ID)"
echo "-----------------------------------"
done
When I run my script this is what I get:
port name: /dev/ttyACM0
manufacturer:
Vendor ID:
Product ID:
I use a raspberry PI3
if I do the same command on a raspberry pi4 with raspberry os I get feedback:
**~** for port in **/dev/ttyACM***; do
done
port name : /dev/ttyACM0
manufacturer : ID_VENDOR=Newland_Auto-ID
ID_VENDOR_ENC=Newland Auto-ID
ID_VENDOR_ID=1eab
ID_VENDOR_FROM_DATABASE=Fujian Newland Computer Co., Ltd
Id vendor : ID_VENDOR_ID=1eab
ID product : ID_MODEL_ID=1a06
I also just tested on a raspberry pi4 with balena OS and I have the same problem
Can someone help me ?
Best Regards
Hi there,
to clarify, are you running this script ON the pi3/pi4 to retrieve the information from a device that is connected to it? Have you tried these instructions for enabling serial on the pi3? I2C and Other Interfaces - Balena Documentation
Firat
September 13, 2023, 11:27am
3
Yes is that, and yes I followed the documentation, I defined my enable_uart=1 variable on my raspberry pi4. Here is an overview of my configuration:
mpous
September 14, 2023, 8:43am
4
Hello @Firat could you please confirm that your container is running with ENV UDEV=1 to your Dockerfile or maybe adding priviledge: true to the service in docker-compose?
Let us know if this works!
Firat
September 14, 2023, 8:55am
5
I found part of the problem. in my local environment I mounted two volumes:
docker run -v /dev:/dev -v /run/udev:/run/udev:ro --rm -it app bash
but when I want to deploy on balena cloud I do not have the rights to mount the volumes:
/dev:/dev and /run/udev:/run/udev:ro
For exemple:
peripheral:
image: app
labels:
io.balena.features.dbus: '1'
volumes:
- 'src:/src'
- '/dev:/dev'
- '/run/udev:/run/udev:ro'
networks:
- default
- peripheral
mem_limit: 300M
privileged: true
environment:
DBUS_SYSTEM_BUS_ADDRESS: 'unix:path=/host/run/dbus/system_bus_socket'
I have this error:
[Error] Deploy failed Bind mounts are not allowed I gonna try with : UDEV=1
mpous
September 14, 2023, 9:05am
6
@Firat why do you try to create the dev or src volumes?
Firat
September 14, 2023, 9:09am
7
@mpous The src volume, I need it for my application. In fact, the container is a C++ application which allows you to have information on devices connected in series. The bash script that I am showing you is more or less an equivalent of what my application does. I use the script to test first. Concerning the dev volume, I noticed that if I run my container (locally on my PC) with the dev and run/udev volumes my script worked. I told myself that if by mounting the volume locally it works, why not test on docker-compose.
Firat
September 14, 2023, 9:41am
8
@mpous Here is the last situation.
In my dockerfile I added:
ENV UDEV=1
my service looks like this:
peripheral:
image: app
labels:
volumes:
- 'src:/src'
networks:
-default
-peripheral
mem_limit: 300M
privileged: true
environment:
I still have the same problem
mpous
September 14, 2023, 10:14am
9
Please change the dev volume for something different and try @Firat
Find more information here Interact with hardware - Balena Documentation
Firat
September 14, 2023, 10:24am
10
Is it possible to do something like that:
- "/dev/ttyACM*:/dev/ttyACM*"
Firat
September 14, 2023, 10:36am
11
I deleted the dev volume and added devices, as in the documentation:
peripheral:
image: app
labels:
volumes:
- 'src:/src'
devices:
- "/dev/ttyACM0:/dev/ttyACM0"
- "/dev/ttyACM1:/dev/ttyACM1"
- "/dev/ttyACM2:/dev/ttyACM2"
networks:
- default
- peripheral
mem_limit: 300M
privileged: true
environment:
I still have the same problem…
Hi there,
To help more effectively troubleshoot, I’d recommend this:
firstly, ignore the container - go to the hostOS, and run the command udevadm info -q property -n /dev/ttyACM0 from the hostOS command line . What comes out, if anything?
if this does give the response you expect, with the correct values, then it means that there is something in the container configuration that is wrong. If even that doesn’t work, then it means that there is something else wrong.
confirm that you can communicate with the device you are connecting to over serial - manually over the command line using a utility such as screen
what is the device you are connecting to the pi? Maybe its not being recognised by Udev and you might need a custom rule?
Firat
September 14, 2023, 11:40am
13
I think the problem is with the container configuration. Here is the output from balena host :
:root@e620ed4:~# udevadm info -q property -n /dev/ttyACM0
DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/tty/ttyACM0
DEVNAME=/dev/ttyACM0
MAJOR=166
MINOR=0
SUBSYSTEM=tty
USEC_INITIALIZED=14256434
ID_VENDOR_ENC=Newland\x20Auto-ID
ID_VENDOR_ID=1eab
ID_MODEL=NLS_IOTC_PRDsUSBVCP
ID_MODEL_ENC=NLS\x20IOTC\x20PRDsUSBVCP
ID_MODEL_ID=1a06
ID_REVISION=0001
ID_SERIAL=Newland_Auto-ID_NLS_IOTC_PRDsUSBVCP_FCCB2972
ID_SERIAL_SHORT=FCCB2972
ID_TYPE=generic
ID_BUS=usb
ID_USB_INTERFACES=:020201:0a0000:
ID_USB_INTERFACE_NUM=00
ID_USB_DRIVER=cdc_acm
ID_PATH=platform-3f980000.usb-usb-0:1.2:1.0
ID_PATH_TAG=platform-3f980000_usb-usb-0_1_2_1_0
ID_MM_CANDIDATE=1
DEVLINKS=/dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0 /dev/serial/by-id/usb-Newland_Auto-ID_NLS_IOTC_PRDsUSBVCP_FCCB2972-if00
TAGS=:systemd:
CURRENT_TAGS=:systemd:
root@e620ed4:~# udevadm info -q property -n $port | grep ID_SERIAL
info: option requires an argument -- 'n'
root@e620ed4:~# udevadm info -q property -n /dev/ttyACM0 | grep ID_SERIAL
If a do the same command in my container, I have nothing:
root@285e58bc8530:/app# udevadm info -q property -n /dev/ttyACM0 | grep ID_SERIAL
Also the full command in my container give this :
MAJOR=166
MINOR=0
SUBSYSTEM=tty
That said, I don’t know what is missing in my configuration. I activated uart with
enable_uart=1
In my dockerfile I also have:
ENV UDEV=1
I have the right labels for the service at docker-compose and I have the privileges:
privileged: true
ah nice. If you restart the container, while keeping everything physically still connected, do you still get the same result? Sometimes I’ve seen udev not pick up on devices if they are plugged at runtime, lets eliminate that as a possibility next
Firat
September 14, 2023, 11:49am
15
Yes, after restarting, I still get the same result:
SSH session disconnected
SSH reconnecting...
Spawning shell...
root@d7a139c8548b:/app# udevadm info -q property -n /dev/ttyACM0
MAJOR=166
MINOR=0
SUBSYSTEM=tty
thanks for confirming.
what does your dockerfile look like? What is the base image you are using?
Firat
September 14, 2023, 12:01pm
17
I use : debian:bullseye-slim
And here my dockerfile:
FROM debian:bullseye-slim
ENV UDEV=1
RUN apt-get update && DEBIAN_FRONTEND=noninteractive apt-get install -y \
build-essential \
qtbase5-dev \
libc6 \
daemontools \
libpcsclite-dev \
ca-certificates \
procps \
libusb-0.1-4 \
libdbus-1-3 \
libpcsclite-dev \
libnfc6 \
i2c-tools \
libqt5serialport5-dev \
&& apt-get clean \
RUN qmake -r && make -j$(nproc)
COPY src/libs/libcomValina-* /usr/lib/
RUN pwd;
RUN ls -la
RUN chmod a+x src/peripherals
RUN chmod a+x src/start.sh
CMD ["src/start.sh"]
I think we’re getting close to the problem. The UDEV=1 feature is only something that works with the balenalib base images: Balena base images - Balena Documentation
You could try
FROM balenalib/%%BALENA_ARCH%%--debian:bullseye
instead.
And in your docker-compose, you shouldn’t need to specify devices, you can change it to:
peripheral:
image: app
labels:
volumes:
- 'src:/src'
networks:
- default
- peripheral
mem_limit: 300M
privileged: true
environment:
sorry i made a typo: FROM balenalib/%%BALENA_ARCH%%-debian:bullseye instead
Firat
September 14, 2023, 12:45pm
21
Thank you very much for your help, I am pleased to announce that the problem is resolved
