I’m having trouble getting balenaCAM to work. I cloned the repository, booted a new device, set the environment variables and pushed the rep to balena. The device came on-line once, set the variables, rebooted and has never been seen again
The hardware is a Pi2 Model B with an 8GB SD card. Here is the log:
25.06.19 20:23:46 (+0100) Supervisor starting
25.06.19 20:24:16 (+0100) Applying configuration change
{"SUPERVISOR_POLL_INTERVAL":"900000"}
25.06.19 20:24:16 (+0100) Applying boot config
{"gpu_mem_1024":"448","gpu_mem_256":"192","gpu_mem_512":"256","start_x":"1","disable_splash ":"1","dtparam":["i2c_arm=on","spi=on","audio=on"],"enable_uart":"1","gpu_mem":"16"}
25.06.19 20:24:17 (+0100) Applied boot config:
{"gpu_mem_1024":"448","gpu_mem_256":"192","gpu_mem_512":"256","start_x":"1","disable_splash":"1","dtparam":["i2c_arm=on","spi=on","audio=on"],"enable_uart":"1","gpu_mem":"16"}
25.06.19 20:24:17 (+0100) Applied configuration change
25.06.19 20:24:19 (+0100) Rebooting
