Build fails with error - Cannot overwrite digest
A recent build has failed with the following error.
[interface]        Step 1/24 : FROM balenalib/raspberrypi3-node:12-stretch-build as build
[interface]        Cannot overwrite digest sha256:39e1529973265976a80a22cc17650daefc2bd0a24cb12fd2a370fc17747190a1
Between this build and the previous we had not made any updates to the interface service.
I am attempting to build the same commit again at the moment, it has started the build from the beginning, therefore, I assume that this issue will be resolved.
I am not looking for help with the above but thought it would be useful to share.
Hi, thanks for letting us know. We’d appreciate if you could follow up with the result of the rebuilt too.
Hi @alexgg,
The following build failed with a “no such image” error (although the error message is slightly more verbose than when I have seen this error before).
Here is a section from the build output, the controller service has not been changed in this push so it should be using a cache for all layers of the dockerfile.
[controller]       Step 18/22 : WORKDIR /app
[controller]       Using cache
[controller]        ---> 26dd7c91f442
[controller]       Step 19/22 : COPY --from=build /app .
[Info]             Still Working...
[controller]       failed to get destination image "sha256:26dd7c91f4427270d3aae1c9cf428836297156758e5d5218032bb9f3ff670de3": No such image: sha256:26dd7c91f4427270d3aae1c9cf428836297156758e5d5218032bb9f3ff670de3
I am running another build and I will share the results from my next build when it finishes.
Hi there. Is this using our builders or are you using balena build locally?
This was running on the Balena servers
Did it say which builder it was running on?
It was using arm03, I hope this is helpful.
I cannot report on the subsequent build as it is still running after 3+ hours.
Ahh. Just how big is the image?
There are 5 services which create images between 0.2 and 1.2 GB. I have not cancelled the build and will try starting it again. Mostly they take 10 - 20 minutes to build but we have not been able to get any of our code onto devices today.
Okay cool. Just out of interest, have you tried balena build locally?
We have spent some time today moving our CI to do local building, however facing some issues with emulated builds where the context and dockerfile for a service are in different folders.
I see. I’ll follow up in that thread.
Hi. We’re looking into the builder errors. Are the logs you posted everything or is there something after the Cannot overwrite digest.... and failed to get destination image....?
Hi @Ereski,
That was the last output from the interface service. At the end of the build it did share a summary output from the build:
[Success]          Successfully uploaded images
[Error]            Some services failed to build:
[Error]              Service: interface
[Error]                Error: Cannot overwrite digest sha256:39e1529973265976a80a22cc17650daefc2bd0a24cb12fd2a370fc17747190a1
[Info]             Built on arm03
[Error]            Not deploying release.
I have the full output if that is useful? Let me know where I can send it over to.
Thank you. I’ll pass this on to the builder maintainer.
Hi, just an update we are looking into this. Will get back to you when this is resolved. Thanks!
Few of our builds failed with the same today so far…
ce18bf01e009e7218af24bc114a63a0b
04e43c4d9a517191a84d60a3baaabaa2
aa3d085adc48457327dbfe46aada89d2
Hello thanks for reporting this, is this the first time you run into this issue? Are you hitting this consistently or was it a one-time error?
Fairly certain we’ve had it in the past, but not to a noticeable degree. Seems to be having a field day today, though, which is rather appreciably slowing my progress.
Two more failed on the build just now:
826b3b0053e5e64fd03a8a9987738681
Thanks, sorry for the delay, we are still looking into this, there have been some issues with the builders lately and we are trying to understand if this error you reported is related to those. Will update you as soon as we have a definite answer on this.
