I am reading, thinking and trying to set up it via the manual, but…
…check it out
At first, I am not sure if this information are right…
also ALL services have release 0.0.0
For example, I have set a new Flightradar24 receiver
after setup cat /etc/fr24feed.ini everything looks ok
but after last step: 24. Restart the fr24feed service under Services by clicking the "cycle" icon next to the service name.
after restart the fr24feed service, the config file is missing
root@xyz123:/# cat /etc/fr24feed.ini
cat: /etc/fr24feed.ini: No such file or directory
Through the CLI I tried this:
>balena fleets
ID NAME SLUG DEVICE TYPE ONLINE DEVICES DEVICE COUNT
2096625 balena-ads-b name/balena-ads-b raspberrypi4-64 1 1
>balena push balena-ads-b
Error: no "Dockerfile[.*]", "docker-compose.yml" or "package.json" file found in source folder "."
The result? My data sharing on flightradar24 = Offline
Can you help me, please?
