Hi, not sure if this is the correct place for this. We are trying to get balena running on our Qualcomm Snapdragon 820 based development board. Not BalenaOS, just ability to run balena containers. We already have docker running on the target. I have a tini-balena and a balena package that I install on the board. After that I can see these processes running:
bash-4.3# ps aux | grep balena
2264 root 1:07 /usr/bin/balenad -H fd://
2400 root 0:39 balena-containerd --config /var/run/balena/containerd/containerd.toml
Here is the version information:
bash-4.3# balena --version
balena version 17.12.0-dev, build 2a85458593353c9a25372b8b2aad7dbdb9bc8c55
On my host computer I cannot balena ssh to the device:
$ balena ssh 192.168.1.53
[debug] original argv0="balena" argv=[/home/ekatzfey/development/balena/balena-cli/balena,/snapshot/versioned-source/bin/balena,ssh,192.168.1.53] length=4
ssh: connect to host 192.168.1.53 port 22222: Connection refused
Nor can I push my balena project:
$ balena push 192.168.1.53
[debug] original argv0="balena" argv=[/home/ekatzfey/development/balena/balena-cli/balena,/snapshot/versioned-source/bin/balena,push,192.168.1.53] length=4
[debug] Using . as build source
[Debug] Checking we can access device
[Debug] Sending request to http://192.168.1.53:48484/ping
Could not communicate with local mode device at address 192.168.1.53
https://forums.balena.io
If I just try to build a container on target I get this:
bash-4.3# balena build example/
Sending build context to Docker daemon 4.608kB
Step 1/7 : FROM resin/aarch64-debian:jessie
jessie: Pulling from resin/aarch64-debian
6ab1b2f5bb07: Pull complete
20e576de7406: Pull complete
86113b948bd9: Pull complete
c7045637fa77: Pull complete
0fc20bb9c8cc: Pull complete
4caa8114bddb: Pull complete
8932f05f17ce: Pull complete
0f56dcbf3e75: Pull complete
e98577514ca1: Pull complete
a137c858e31e: Pull complete
80609c6f7f2d: Pull complete
e7a5b13f47f4: Pull complete
d5fbf9afa7c9: Pull complete
2e96397a9d11: Pull complete
Total: 35.51MB/35.51MB
Digest: sha256:d830b7287ec34ab7202bb7a263b2734d135d0eb9956587b9a2e57f0649989f64
Status: Downloaded newer image for resin/aarch64-debian:jessie
# Executing 1 build trigger
---> Running in 87a1090c68ef
OCI runtime create failed: container_linux.go:296: starting container process caused "process_linux.go:279: applying cgroup configuration for process caused \"failed to write 0-7\\n to cpuset.cpus: write /sys/fs/cgroup/cpuset/docker/cpuset.cpus: invalid argument\"": unknown
bash-4.3# echo 0-1 > /sys/fs/cgroup/cpuset/docker/cpuset.cpus
---> Running in b16f68a44f41
OCI runtime create failed: container_linux.go:296: starting container process caused "process_linux.go:398: container init caused \"could not create session key: function not implemented\"": unknown
How do I go about debugging all of this? Is there some sort of bringup guide that explains how to get a new implementation working?
