Hello!
I use Balena to deploy software to Jetson TX2 devices. Our Docker images are hosted in GItlab, and I would like a way to build the docker image in the Gitlab CI system. However, I can’t seem to get ROS to install correctly.
My gitlab CI config is this:
image: "docker:19"
docker_image:
services:
- docker:dind
script:
- cd $CI_PROJECT_DIR/src/payload
- docker build --file Dockerfile.baseImage --tag CIimage
However, when I run it, I get the following error:
Unpacking ros-melodic-ros-base (1.4.1-0bionic.20200531.064541) ...
[2759](https://gitlab.com/br_consultants/consultants_repo/-/jobs/669069689#L2759)Errors were encountered while processing:
[2760](https://gitlab.com/br_consultants/consultants_repo/-/jobs/669069689#L2760) /tmp/apt-dpkg-install-PLJoTI/051-humanity-icon-theme_0.6.15_all.deb
[2761](https://gitlab.com/br_consultants/consultants_repo/-/jobs/669069689#L2761)E: Sub-process /usr/bin/dpkg returned an error code (1)
[2762](https://gitlab.com/br_consultants/consultants_repo/-/jobs/669069689#L2762)The command '/bin/sh -c apt-get install -y ros-melodic-ros-base' returned a non-zero code: 100
[2764](https://gitlab.com/br_consultants/consultants_repo/-/jobs/669069689#L2764)ERROR: Job failed: exit code 100
I’ve currently been using the FROM balenalib/aarch64-ubuntu:bionic image and I’ve surrounded my installation calls with the RUN [ “cross-build-start” ] and RUN [ “cross-build-end” ] commands.
Which I thought would handle the emulation. Any advice on what I’m doing wrong?
