Best practice Balena shutdown/reboot RPI4 via Python
what is the best practice to shutdown or reboot the Pi4 Balena via Python?
I tried
via subprocess or systemctl (not found)
os.system("sudo shutdown -r now")
System has not been booted with systemd as init system (PID 1). Can't operate.
Failed to connect to bus: Host is down
Failed to talk to init daemon.
How should one shutdown the system or reboot it? Thanks
Hi. You can call the supervisor using the HTTP API: https://www.balena.io/docs/reference/supervisor/supervisor-api/. Specifically:
Thanks it worked!
