Could it be that this is simply an issue of metrics?
In general ethernet devices get assigned a better routing metric than wireless or gsm.
You can check this with ip route.
You can try to force the route to use your 4G by adding a rule to your connection settings. nmcli connection modify <name> ipv4.routes 8.8.8.8/32 <metric>
Regarding your DNS entries getting replaced all together, you can try to add ipv4.ignore-auto-dns to your ethernet connection settings; that should prevent DHCP from adding new DNS servers.
Despite the route metric favoring cellular connection over the ethernet connection, it seems that whenever I plug the ethernet cable, it automatically tries to resolve DNS “through it”
Can you show your /etc/resolv.conf in both scenarios?
My guess is that your DHCP adds a server in the 192.168.2.9/24 subnet, which would get picked up with metric 6 as the cellular only has a /30 subnet.
Again, can you also try it with ipv4.ignore-auto-dns enabled on your ethernet connection?
That should prevent DHCP from adding new servers.
If you don’t want to discard the DHCP DNS altogether, it seems there’s also a settingipv4.dns-priority that might help in fixing the order of your nameservers.
Maybe try setting that on both connections, with the cellular having a lower value; note that the default values are 50 for VPN and 100 for others and 0 selects the default.
Based on your routing table, it should then first try the 172.30.8.5 and 172.30.8.6 via cdc-wdm0, only going to 192.168.2.10 via eth0
