balenaHub Submissions
As documented here, you can submit your balena projects for inclusion in balenaHub!
However, just to recap, the steps are fairly simple:
  • Your app should work using the deploy with balena button, and assume defaults to enable people to get up and running quickly with the minimum of configuration.
  • You should provide complete instructions in the form of a readme or documentation within the application repo.
  • Your app should contain a balena.yml file with all the necessary metadata, along with an icon which will be used for listing on balenaHub.
  • Check out this example app!
Once you have those requirements met, simply fill out the form located here to let us know: https://hub.balena.io/submit
Happy Hacking!
hello! is the /submit endpoint still supported? i am redirected to the main page of balena hub. I’d love to submit a new project.
@saveriogzz you can publish on balenaHub through your balenaCloud dashboard by following these steps: Develop with Apps | balena docs
