Hi!
Currently i am facing the task of building an application for a balena app (armv7hf) with concourse CI (amd64).
I already posted a question at the concourse forums (https://discuss.concourse-ci.org/t/running-arm-image-with-concourse-on-amd64/1716/3) and thought it would be useful to ask from this side as well.
Long story short:
Does anybody can tell me why this pipeline does not run using the official balena ubuntu base image for armv7hf?
resources:
- name: base-image
type: docker-image
source:
repository: balenalib/armv7hf-ubuntu
tag: bionic
jobs:
- name: arm_test
plan:
- get: base-image
trigger: true
- task: run
config:
platform: linux
image_resource:
type: docker-image
source:
tag: bionic
run:
path: /bin/bash
args:
- -c
uname -a
I get this error in concourse:
Backend error: Exit status: 500, message: {"Type":"","Message":"runc exec: exit status 1: exec failed: container_linux.go:345: starting container process caused \"exec format error\"\n","Handle":"","ProcessID":"","Binary":""}
However running the same on my local machine works:
$ docker run -it --rm $REGISTRY/elbb/armv7hf/ubuntu/bionic/base /bin/bash
Starting with UID : 9001
user@9ab2026141c7:/$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.3 LTS"
