I am running Jetson TX2s on an Aetina N510 carrier board. The carrier board is community supported and pre-build images (if slightly outdated) can be downloaded from the application page.
The application is a N510 application. However, I cannot successfully do a Balena OS update from
Host OS: balenaOS 2.26.0+rev1
Mode: production
Supervisor: 8.0.0
to the newest supported 2.31.2
All I get is a stderr message on the first run and no error message on subsequent runs.
Furthermore, the webUI actually let’s me select the jetson-tx2 board 2.35.0 version, which is not yet released for the n510-tx2 board.
I will for now manually upgrade, but will I be able to do this upgrade remotely in the future?
Hey there! We’re pending a UI deploy that will make it possible for you to manage the updates (hopefully this week). Still, if you are in a hurry, please let us know the device UUIDs and the FleetOps team can handle that for you!
We are making steady progress and hope to update them soon! BTW you should also definitely watch this repo: https://github.com/balena-os/balena-jetson-tx2 so you get more real-time updates for it if you are not doing so already!
