After configuring my Balena device to use the redsocks proxy redirector configured via Balena Supervisor I’m experiencing a series of issues…
To give some context:
- I’m using the example set by balena on how to use this feature (GitHub - balenalabs/proxy-tunnel: Connecting your device(s) to balenaCloud from behind a compatible proxy.) by using an SSH Connection to an EC2 instance running a Dante Proxy Server
"network": {
"proxy": {
"type": "socks5",
"ip": "127.0.0.1",
"port": 1080,
"noProxy": [
"${PROXY_IP}"
"hostname": "7c83344001c3.videolink.io"
- By executing the troubleshooting CURL command to use the redoscks redirector I’m getting healthy communication over my proxy
root@7c83344001c3:/src# curl -x socks5://127.0.0.1:1080 https://ipinfo.io/ | jq
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 316 100 316 0 0 1541 0 --:--:-- --:--:-- --:--:-- 1549
"ip": "${PROXY_IP}",
"hostname": "ec2-${PROXY_IP}.compute-1.amazonaws.com",
"city": "Ashburn",
"region": "Virginia",
"country": "US",
"loc": "39.0437,-77.4875",
"org": "AS14618 Amazon.com, Inc.",
"postal": "20147",
"timezone": "America/New_York",
"readme": "https://ipinfo.io/missingauth"
So everything is configured as expected… And even like that I’m finding issues like:
- If Proxy Settings are configured the host loses communication with Docker Internal bridge network containers… Containers that before had exposed a port and that could be reached from the host by using this setting they lost all communication… I suspect this is related to Balena Engine and a restart of it when applying proxy settings or a deeper issue where if proxy redirector is configured then the containers in the internal network do not work.
- My supervisor cannot connect to Balena API, even if the proxy redirector is set properly… Obviously, updates also no not work and my device goes to
VPN Only
Opened support ticket as well, have not got back any information yet, but it would be nice if this is a feature that actually works or if it has even been tested.
Regards
