HI,
Would like to know if anybody has succcesfully built balena OS using apple M1 host chip or is it not supported yet?. I am using VM with Ubuntu running on MacOS Monterey 12.2.1. But keep getting this error (Please note, this was also built on ubuntu 20.04, 21,10 with almost same error):
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing shell function do_install
| NOTE: make -j 4 DESTDIR=/home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/image install-static
| cd jim && CFLAGS=" -Os -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0=/usr/src/debug/usb-modeswitch/2.5.2-r0 -fdebug-prefix-map=/home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0=/usr/src/debug/usb-modeswitch/2.5.2-r0 -fdebug-prefix-map=/home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/recipe-sysroot= -fdebug-prefix-map=/home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/recipe-sysroot-native= -Wall" CC="aarch64-poky-linux-gcc -mcpu=cortex-a53 -march=armv8-a+crc -fstack-protector-strong -Os -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security -Wdate-time --sysroot=/home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/recipe-sysroot" ./configure --disable-lineedit --with-out-jim-ext="stdlib posix load signal syslog" --prefix=/usr
| install -D --mode=755 usb_modeswitch /home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/image/usr/sbin/usb_modeswitch
| install -D --mode=755 usb_modeswitch.sh /home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/image/lib/udev/usb_modeswitch
| install -D --mode=644 usb_modeswitch.conf /home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/image/etc/usb_modeswitch.conf
| install -D --mode=644 usb_modeswitch.1 /home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/image/usr/share/man/man1/usb_modeswitch.1
| install -D --mode=644 usb_modeswitch_dispatcher.1 /home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/image/usr/share/man/man1/usb_modeswitch_dispatcher.1
| install -D --mode=755 usb_modeswitch_dispatcher /home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/image/usr/sbin/usb_modeswitch_dispatcher
| install -d /home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/image/var/lib/usb_modeswitch
| test -d /home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/image/etc/init -a -e /sbin/initctl && install --mode=644 usb-modeswitch-upstart.conf /home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/image/etc/init || test 1
| test -d /home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/image/etc/systemd/system -a \( -e /usr/bin/systemctl -o -e /bin/systemctl \) && install --mode=644 usb_modeswitch@.service /home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/image/etc/systemd/system || test 1
| autosetup/system.tcl:204: Error: /home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/usb-modeswitch-2.5.2/jim/autosetup/config.guess: unable to guess system type
| This script, last modified 2010-09-24, has failed to recognize
| the operating system you are using. It is advised that you
| download the most up to date version of the config scripts from
| http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
| and
| http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD
| If the version you run (/home/azmi/workdir/project1/balena-raspberrypi/build/tmp/work/cortexa53-poky-linux/usb-modeswitch/2.5.2-r0/usb-modeswitch-2.5.2/jim/autosetup/config.guess) is already up to date, please
| send the following data and any information you think might be
| pertinent to <config-patches@gnu.org> in order to provide the needed
| information to handle your system.
| config.guess timestamp = 2010-09-24
| uname -m = aarch64
| uname -r = 5.15.0-22-generic
| uname -s = Linux
| uname -v = #22-Ubuntu SMP Tue Feb 8 13:17:51 UTC 2022
| /usr/bin/uname -p = aarch64
| /bin/uname -X =
| hostinfo =
| /bin/universe =
| /usr/bin/arch -k =
| /bin/arch = aarch64
| /usr/bin/oslevel =
| /usr/convex/getsysinfo =
| UNAME_MACHINE = aarch64
| UNAME_RELEASE = 5.15.0-22-generic
| UNAME_SYSTEM = Linux
| UNAME_VERSION = #22-Ubuntu SMP Tue Feb 8 13:17:51 UTC 2022
| in procedure 'use' called at file "auto.def", line 5
| in procedure 'use' called at file "autosetup/cc.tcl", line 29
| in procedure 'config_guess' called at file "autosetup/system.tcl", line 204
| Try: 'configure --debug' for a full stack trace
| make: *** [Makefile:46: jim/libjim.a] Error 1
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
ERROR: Task (/home/azmi/workdir/project1/balena-raspberrypi/build/../layers/meta-balena/meta-balena-common/recipes-support/usb-modeswitch/usb-modeswitch_2.5.2.bb:do_install) failed with exit code '1'
Best regards,
Azmi.
