balena login fails after new server setup, getting BalenaRequestError
When I try to do ‘balena login’ I get:
$ balena login --credentials --email xx@xxxx.org --password xxxxx --debug        (10-18 14:10)
[debug] new argv=[/home/khoran/programs/balena-cli/balena,/snapshot/balena-cli/bin/balena,login,--credentials,--email,xx@xxxx.org,--password,xxxx] length=8
[debug] Deprecation check: Cache miss for the balena CLI next major version release date.
[debug] Will query https://registry.npmjs.org/balena-cli/18.0.0
 _            _
| |__   __ _ | |  ____  _ __    __ _
| '_ \ / _` || | / __ \| '_ \  / _` |
| |_) | (_) || ||  ___/| | | || (_) |
|_.__/ \__,_||_| \____/|_| |_| \__,_|
Logging in to ob.galcom.org
[debug] Event tracking error: Timeout awaiting 'response' for 0ms
BalenaRequestError: Request error: <!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<title>Error</title>
</head>
<body>
<pre>Cannot GET /actor/v1/whoami</pre>
</body>
</html>
<html lang="en">
<head>
</head>
<body>
</body>
</html>
    at Object.<anonymous> (/snapshot/balena-cli/node_modules/balena-request/build/request.js:193:27)
    at Generator.next (<anonymous>)
    at fulfilled (/snapshot/balena-cli/node_modules/tslib/tslib.js)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
https://www.balena.io/docs/reference/balena-cli/#support-faq-and-troubleshooting
I have followed the openbalena getting started guide. I ran the quickstart and generated the certificates OK. I’ve set the NODE_EXTRA_CA_CERTS environment variable.
Running
curl -k https://api.ob.galcom.org/ping
results in “OK”.
I logged into the api container and ran tcpdump -A so I could see the HTTP traffic. It seem that the “/login_” endpoint succeeds and returns a token. But then every other url fails:
POST /login_ HTTP/1.1
X-Balena-Client: balena-sdk/18.0.2
Content-Type: application/json
Accept-Encoding: compress, gzip
Accept: */*
Content-Length: 56
User-Agent: node-fetch/1.0 (+https://github.com/bitinn/node-fetch)
Connection: close
Host: api.ob.galcom.org
X-Forwarded-Proto: https
X-Forwarded-For: 192.168.0.1
{"username":"xx@xxxx.org","password":"xxx"}
HTTP/1.1 200 OK
GET /actor/v1/whoami HTTP/1.1
Authorization: Bearer  XXXXXX<confirmed this is token returned by login_>
Accept: */*
Connection: close
HTTP/1.1 404 Not Found
X-Frame-Options: DENY
X-Content-Type-Options: nosniff
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: GET, PUT, POST, PATCH, DELETE, OPTIONS, HEAD
Access-Control-Allow-Headers: Content-Type, Authorization, Application-Record-Count, MaxDataServiceVersion, X-Requested-With, X-Balena-Client
Access-Control-Allow-Credentials: true
Access-Control-Max-Age: 86400
Content-Security-Policy: default-src 'none'
Content-Type: text/html; charset=utf-8
Content-Length: 154
Vary: Accept-Encoding
Date: Wed, 18 Oct 2023 18:30:22 GMT
Connection: close
Been fighting with this one for a whole day. The API container never logs anything beyond the initial message that systemd started. PRODUCTION_MODE is false.
Any ideas? Thanks.
Just found this article after posting: Login not working with balena-cli.
Downgrading balena-cli to 16.7.6 also fixed my problem.
