i added the string “w1-gpio” to the dt-overlays in the device configuration page and rebooted. All seems good, but it is unclear how I can test if the 1-wire feature has been successfully added. Any help would be greatly appreciated.
Hello William, you should be able to see the kernel module listed if you run lsmod on the hostOS. It should be named w1-gpio or w1_gpio if I recall correctly.
