balena-engine not starting
Hi Alexis,
ok, this is good to know. From now on I will make sure to use “–nolive” when using push.
The other command are valuable too, if the problem appears again.
In order to continue developing, I deleted the contents of /mnt/data manually.
Apparently Balena rebuilt everthing necessary and the device booted cleanly.
Thank you very much for your help,
Peter
