I am trying to test out my environment, but have run into this issue. I cam across this post Balena deploy Progress Error and have also tried putting our certificate on haproxy container, but that did not result in any change. I tried rebuilding haproxy container (placing a copy command in Dockerfile). I also just tried copying the pem to the container.
docker cp domain.edu.pem openbalena_haproxy_1_62aa8dc129eb:/etc/ssl/private/open-balena.pem
then restarting the containers. I just keep getting the error below when I try to deploy thetest app.
balena deploy Snake --logs --source . --emulated
[Debug] Parsing input...
[Debug] Loading project...
[Debug] Resolving project...
[Debug] Failed to resolve project:
[Debug] AggregateError of:
[Debug] Error: ENOENT: no such file or directory, open '/root/open-balena/projects/sense-snake/docker-compose.yml'
[Debug] Error: ENOENT: no such file or directory, open '/root/open-balena/projects/sense-snake/docker-compose.yaml'
[Info] Creating default composition with source: /root/open-balena/projects/sense-snake
[Debug] Creating project...
[Info] Everything is up to date (use --build to force a rebuild)
[Info] Creating release...
[Debug] Tagging images...
[Debug] Authorizing push...
[Info] Pushing images to registry...
Retrying "registry.iot.domain.edu/v2/3178f570ccf5bf48ed0151f2880d493a:latest" after 2.00s (1 of 3) due to: Error: Get https://registry.iot.domain.edu/v2/: x509: certificate signed by unknown authority
Retrying "registry.iot.domain.edu/v2/3178f570ccf5bf48ed0151f2880d493a:latest" after 2.80s (2 of 3) due to: Error: Get https://registry.iot.domain.edu/v2/: x509: certificate signed by unknown authority
Retrying "registry.iot.domain.edu/v2/3178f570ccf5bf48ed0151f2880d493a:latest" after 3.92s (3 of 3) due to: Error: Get https://registry.iot.domain.edu/v2/: x509: certificate signed by unknown authority
[Debug] Saving image registry.iot.domain.edu/v2/3178f570ccf5bf48ed0151f2880d493a
[Debug] Untagging images...
[Info] Saving release...
[Error] Deploy failed
at Stream.<anonymous> (/usr/lib/node_modules/balena-cli/node_modules/docker-progress/index.js:53:19)
at Stream.emit (events.js:193:13)
at Stream.EventEmitter.emit (domain.js:481:20)
at drain (/usr/lib/node_modules/balena-cli/node_modules/through/index.js:36:16)
at Stream.stream.queue.stream.push (/usr/lib/node_modules/balena-cli/node_modules/through/index.js:45:5)
at Parser.parser.onToken (/usr/lib/node_modules/balena-cli/node_modules/JSONStream/index.js:132:18)
at Parser.proto.write (/usr/lib/node_modules/balena-cli/node_modules/jsonparse/jsonparse.js:135:34)
at Stream.<anonymous> (/usr/lib/node_modules/balena-cli/node_modules/JSONStream/index.js:23:12)
at Stream.stream.write (/usr/lib/node_modules/balena-cli/node_modules/through/index.js:26:11)
at IncomingMessage.ondata (_stream_readable.js:705:22)
at IncomingMessage.emit (events.js:193:13)
at IncomingMessage.EventEmitter.emit (domain.js:481:20)
at addChunk (_stream_readable.js:295:12)
at readableAddChunk (_stream_readable.js:276:11)
at IncomingMessage.Readable.push (_stream_readable.js:231:10)
at HTTPParser.parserOnBody (_http_common.js:126:22)
at Socket.socketOnData (_http_client.js:447:22)
at Socket.emit (events.js:193:13)
at Socket.EventEmitter.emit (domain.js:481:20)
at Socket.Readable.push (_stream_readable.js:231:10)
at Pipe.onStreamRead (internal/stream_base_commons.js:150:17)
https://forums.balena.io
