One of our devices is in a balena engine rebooting loop. During which IO wait was through the roof (logging these errors?). Last 1000 lines of balena logs attached, not sure whats relevant - it’s very verbose…
Client:
Version: 18.09.10-dev
API version: 1.39
Go version: go1.10.8
Git commit: 7cb464a406748016f2df0c31a9851d20456a3d31
Built: Fri Nov 1 05:04:49 2019
OS/Arch: linux/arm
Experimental: false
Server:
Engine:
API version: 1.39 (minimum version 1.12)
OS/Arch: linux/arm
Experimental: true
Thank you for the report and the log! It looks as if balenaEngine faulted on an issue with a missing container reference. Would it be possible to answer a few questions for us?
balenaOS version and Supervisor version
Is this a balenaCloud attached device, unmanaged or using openBalena?
Have you seen this failure regularly?
We’d love to be able to investigate more if you see this again and the device is available.
It’s not the first time balena engine has behaved like this, although never investigated. Usually when balena engine gets faulty the device is just rebooted. This time it was on a development device - so I collected what information I could prior to reboot.
