Balena Config Inject Failing for Local TX2 Built
Hello! I’m trying to test a local build of the jetsontx2 image for a customer carrier board.
See my PR here for context: https://github.com/balena-os/balena-jetson/pull/71
When I try to run the local configure command below, I get the error listed. Can anyone help me figure out how to insert the config.json so I can test this image?
Command
balena config inject testbed-tx2.config.json --type jetson-tx2 --drive /dev/disk2
Error
Unsupported filesystem.
variable: “set DEBUG=1” on a Windows command prompt, “$env:DEBUG = 1” on
powershell, or “export DEBUG=1” on Linux or macOS.
If you need help, don’t hesitate in contacting our support forums at
https://forums.balena.io
For CLI bug reports or feature requests, have a look at the GitHub issues or
Hi, you need to make sure the “–drive” parameter points to the correct location: https://www.balena.io/docs/reference/balena-cli/#config-inject-file . Have you mounted the OS image you built?
Hey there! No I was just trying to do it from the SD card. What’s the best way to mount the image file?
losetup --show -fP
losetup --show -fP
losetup --show -fP YOUR_IMAGE_FILE
and then you can use the yielded loop device
Ok perfect that worked. Now I unmount and then use the same image file?
Yes, unmount and use that image which you just modified
Perfect! I unmounted with this command: sudo losetup -d /dev/loop19
Is that the correct way?
Yes, that is it
Cool. Thank you so much for your help!
You are welcome
