I am getting this error
getting fin-version tag to v1.1.1…
29.06.21 11:05:39 (-0500) finblock supervisor busy…
29.06.21 11:05:39 (-0500) finblock Error: cannot reach supervisor
29.06.21 11:05:39 (-0500) finblock at /usr/src/app/index.js:134:17
I copy everything from the finabler from github. Is there any setting that i am missing?
it wont let me sleep and is not even answering to get request.
when I try via the terminal on the host to sleep it i get this error…
something to do with the supervisor
Can you paste your docker-compose.yml? Just confirming, to get Finblock to work, you need to add the Finblock service like this:
version: '2.1'
volumes:
fin:
services:
finabler:
restart: always
image: balenablocks/finabler:latest
network_mode: host
privileged: true
volumes:
- 'fin:/data/firmware'
labels:
io.balena.features.balena-api: '1'
expose:
- "1337"
Can you paste the output of the command journalctl -u resin-supervisor --no-pager, thanks!
this is my project structure
I ran this -u resin-supervisor --no-pager , on the HostOs terminal
this is the ouput
Hmm, we recently changed the name of the supervisor service on latest balenaOS. Hence the reason why it’s showing no entries present. Can you run this command instead journalctl -u balena-supervisor --no-pagerand post the output.
did a restart of the module and ran the command
dont know if having privledge"true" in both containers messes this up
