While trying to update to v4 I accidentally removed my config folder. I didn’t check if the backup finished before this happened, turns out it failed and so I don’t have a backup. Good lesson to learn here.
When I checkout the v3.8.3 tag everything starts successfully and I can see the devices, but they seem to not be able to connect because they display as “offline”. I also can’t ssh into any of those.
What I do have:
- Docker volumes
- One of the config.json files that was used to provision a device
- API-key that I used to ssh into the container (using this HowTo)
Is there a way to get this to work again?
