I’ve installed balenaOS using following the Getting Started guide.
Steps taken
- Downloaded the production image for the Raspberry Pi 4: BalenaOS 2.41.0+rev4
- Installed the CLI
- Configured Network SSID and Network Key
- Booted up the device
- The device responds to mydevice.local and is given a IPV4 address through DHCP on my router.
From @agabq in another thread:
If you use the production image serial or video consoles are disabled. You can use only the console from dashboard.
Since I have installed the production image how do I access the console from the dashboard? Port 80 and port 443 does not seem to be opened.
nmap 192.168.x.y -A 40.7s Wed Nov 27 16:57:46 2019
Starting Nmap 7.80 ( https://nmap.org ) at 2019-11-27 16:57 CET
Nmap scan report for 192.168.x.y
Host is up (1.0s latency).
All 1000 scanned ports on 192.168.x.y are closed
Service detection performed. Please report any incorrect results at https://nmap.org/submit/ .
Nmap done: 1 IP address (1 host up) scanned in 16.58 seconds
