It starts, claims to be doing x% then y% etc etc until 83% then claims the device failed.
Putting the rasbian zip on to a fresh drive using a windows 10 laptop and a usb adapter.
It gets to 83%, pauses for a good while before the fails, hovering gives \.\PhysicalDrive1:ETIMEDOUT: connection timed out, write
Could you please enable the Developer Tools (you should be able to select this from Etcher’s menu system), rerun a flash and paste the output from the ‘Console’ tab into a response here? This will hopefully give us some initial idea of what might be going on.
Hi, you can also access the Developer Tools of the application on Windows by pressing ctrl + shift + i, then you’ll see the Console tab of the DevTools where you’ll find the application logs.
The ones we’re looking after are when the issue happens
