I try to flash HomeAssistant OS on a M.2 SATA SSD.
The M.2 SSD is on my MSI Tomahawk Max. I can acces the storage and write on it.
After flashing HomeAssistant OS it fails after 100 % of verification.
I cant flash other Distributions too.
Can somebody help me?
Verifying 1 device, 100% at 255.30 MB/s (total 255.30 MB/s) eta in 0s with 0 failed devices
gui.js:46 Tue Sep 20 2022 10:40:52 GMT+0200 (Mitteleuropäische Sommerzeit) Flash error ({“image”:{“size”:6442450944,“compressedSize”:342290392,“hasMBR”:true,“path”:“C:\Users\new-b\Downloads\haos_generic-x86-64-9.0.img.xz”,“partitions”:[{“offset”:1048576,“size”:33554432,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“B3DD0952-733C-4C88-8CBA-CAB9B8B4377F”,“name”:“hassos-boot”,“index”:1},{“offset”:34603008,“size”:25165824,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“26700FC6-B0BC-4CCF-9837-EA1A4CBA3E65”,“name”:“hassos-kernel0”,“index”:2},{“offset”:59768832,“size”:268435456,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“8D3D53E3-6D49-4C38-8349-AFF6859E82FD”,“name”:“hassos-system0”,“index”:3},{“offset”:328204288,“size”:25165824,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“FC02A4F0-5350-406F-93A2-56CBED636B5F”,“name”:“hassos-kernel1”,“index”:4},{“offset”:353370112,“size”:268435456,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“A3EC664E-32CE-4665-95EA-7AE90CE9AA20”,“name”:“hassos-system1”,“index”:5},{“offset”:621805568,“size”:8388608,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“33236519-7F32-4DFF-8002-3390B62C309D”,“name”:“hassos-bootstate”,“index”:6},{“offset”:630194176,“size”:100663296,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“F1326040-5236-40EB-B683-AAA100A9AFCF”,“name”:“hassos-overlay”,“index”:7},{“offset”:730857472,“size”:1342177280,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“A52A4597-FA3A-4851-AEFD-2FBE9F849079”,“name”:“hassos-data”,“index”:8}],“isCompressed”:true,“name”:“haos_generic-x86-64-9.0.img”,“isSizeEstimated”:false,“extension”:“xz”},“drives”:[{“size”:16013942784,“isVirtual”:false,“enumerator”:“SCSI”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive2”,“error”:null,“isReadOnly”:false,“displayName”:“\\.\PhysicalDrive2”,“blockSize”:512,“isSCSI”:true,“isRemovable”:false,“device”:“\\.\PhysicalDrive2”,“busVersion”:“2.0”,“isSystem”:true,“busType”:“SATA”,“isCard”:false,“isUSB”:false,“devicePath”:null,“mountpoints”:,“description”:“DEM24-16GM41BC1DC-PC”,“isUAS”:false}],“driveCount”:1,“uuid”:“5c992466-a891-4d70-ac11-19e45cea6b45”,“flashInstanceUuid”:“5c992466-a891-4d70-ac11-19e45cea6b45”,“error”:{“name”:“Error”,“message”:“The module ‘\\?\C:\Users\new-b\AppData\Local\Programs\balena-etcher\resources\app\generated\modules\mountutils\build\Release\MountUtils.node’\nwas compiled against a different Node.js version using\nNODE_MODULE_VERSION 87. This version of Node.js requires\nNODE_MODULE_VERSION 80. Please try re-compiling or re-installing\nthe module (for instance, using npm rebuild
or npm install
).”,“stack”:“Error: The module ‘\\?\C:\Users\new-b\AppData\Local\Programs\balena-etcher\resources\app\generated\modules\mountutils\build\Release\MountUtils.node’\nwas compiled against a different Node.js version using\nNODE_MODULE_VERSION 87. This version of Node.js requires\nNODE_MODULE_VERSION 80. Please try re-compiling or re-installing\nthe module (for instance, using npm rebuild
or npm install
).\n at process.func [as dlopen] (electron/js2c/asar.js:140:31)\n at Object.Module._extensions…node (internal/modules/cjs/loader.js:1034:18)\n at Object.func [as .node] (electron/js2c/asar.js:140:31)\n at Module.load (internal/modules/cjs/loader.js:815:32)\n at Module._load (internal/modules/cjs/loader.js:727:14)\n at Function.Module._load (electron/js2c/asar.js:738:28)\n at Module.require (internal/modules/cjs/loader.js:852:19)\n at require (internal/modules/cjs/helpers.js:74:18)\n at Object. (C:\Users\new-b\AppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js:1:87500)\n at webpack_require (C:\Users\new-b\AppData\Local\Programs\balena-etcher\resources\app\generated\child-writer.js:35:579807)”},“sample”:0.1,“applicationSessionUuid”:“973581f0-ebdb-4016-8abe-b4c97aac4edc”,“flashingWorkflowUuid”:“60dcac6c-0622-4f3d-8729-284d47ac8302”})
gui.js:46 Finish: 6442450944
gui.js:46 Terminating IPC server
gui.js:46 Flash results {results: {…}, cancelled: false, skip: false}
gui.js:46 Tue Sep 20 2022 10:40:52 GMT+0200 (Mitteleuropäische Sommerzeit) Done ({“image”:{“size”:6442450944,“compressedSize”:342290392,“hasMBR”:true,“path”:“C:\Users\new-b\Downloads\haos_generic-x86-64-9.0.img.xz”,“partitions”:[{“offset”:1048576,“size”:33554432,“type”:“C12A7328-F81F-11D2-BA4B-00A0C93EC93B”,“guid”:“B3DD0952-733C-4C88-8CBA-CAB9B8B4377F”,“name”:“hassos-boot”,“index”:1},{“offset”:34603008,“size”:25165824,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“26700FC6-B0BC-4CCF-9837-EA1A4CBA3E65”,“name”:“hassos-kernel0”,“index”:2},{“offset”:59768832,“size”:268435456,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“8D3D53E3-6D49-4C38-8349-AFF6859E82FD”,“name”:“hassos-system0”,“index”:3},{“offset”:328204288,“size”:25165824,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“FC02A4F0-5350-406F-93A2-56CBED636B5F”,“name”:“hassos-kernel1”,“index”:4},{“offset”:353370112,“size”:268435456,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“A3EC664E-32CE-4665-95EA-7AE90CE9AA20”,“name”:“hassos-system1”,“index”:5},{“offset”:621805568,“size”:8388608,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“33236519-7F32-4DFF-8002-3390B62C309D”,“name”:“hassos-bootstate”,“index”:6},{“offset”:630194176,“size”:100663296,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“F1326040-5236-40EB-B683-AAA100A9AFCF”,“name”:“hassos-overlay”,“index”:7},{“offset”:730857472,“size”:1342177280,“type”:“0FC63DAF-8483-4772-8E79-3D69D8477DE4”,“guid”:“A52A4597-FA3A-4851-AEFD-2FBE9F849079”,“name”:“hassos-data”,“index”:8}],“isCompressed”:true,“name”:“haos_generic-x86-64-9.0.img”,“isSizeEstimated”:false,“extension”:“xz”},“drives”:[{“size”:16013942784,“isVirtual”:false,“enumerator”:“SCSI”,“logicalBlockSize”:512,“raw”:“\\.\PhysicalDrive2”,“error”:null,“isReadOnly”:false,“displayName”:“\\.\PhysicalDrive2”,“blockSize”:512,“isSCSI”:true,“isRemovable”:false,“device”:“\\.\PhysicalDrive2”,“busVersion”:“2.0”,“isSystem”:true,“busType”:“SATA”,“isCard”:false,“isUSB”:false,“devicePath”:null,“mountpoints”:,“description”:“DEM24-16GM41BC1DC-PC”,“isUAS”:false}],“driveCount”:1,“uuid”:“5c992466-a891-4d70-ac11-19e45cea6b45”,“status”:“finished”,“flashInstanceUuid”:“5c992466-a891-4d70-ac11-19e45cea6b45”,“errors”:[{“name”:“Error”,“description”:“DEM24-16GM41BC1DC-PC”,“device”:“\\.\PhysicalDrive2”}],“devices”:{“failed”:1,“successful”:0},“bytesWritten”:6442450944,“sourceMetadata”:{“isCompressed”:true,“name”:“haos_generic-x86-64-9.0.img”,“size”:6442450944,“compressedSize”:342290392,“isSizeEstimated”:false},“sample”:0.1,“applicationSessionUuid”:“973581f0-ebdb-4016-8abe-b4c97aac4edc”,“flashingWorkflowUuid”:“60dcac6c-0622-4f3d-8729-284d47ac8302”})
gui.js:46 Tue Sep 20 2022 10:40:52 GMT+0200 (Mitteleuropäische Sommerzeit) SafeWebview loaded ({“event”:{“id”:73,“url”:“https://www.balena.io/etcher/success-banner/?borderTop=false&darkBackground=true&etcher-version=1.7.9&api-version=2&optOutAnalytics=false",“method”:“GET”,“timestamp”:1663663252896.869,“resourceType”:“mainFrame”,“ip”:“2a05:d014:275:cb01:8909:43f0:2069:7b77”,“fromCache”:false,“statusLine”:"HTTP/1.1 200”,“statusCode”:200,“responseHeaders”:{“age”:[“63583”],“cache-control”:[“public, max-age=0, must-revalidate”],“content-encoding”:[“gzip”],“content-length”:[“7272”],“content-type”:[“text/html; charset=UTF-8”],“date”:[“Mon, 19 Sep 2022 15:01:07 GMT”],“etag”:[“"11f609cbc3b8f3f6a7800cf9a09fc918-ssl-df"”],“link”:[“</webpack-runtime-da3e382f1aaf991aeea8.js>; rel=preload; as=script, </styles-c4fa86dfd4ad05097eee.js>; rel=preload; as=script, </framework-004503f2df4bb68d43f8.js>; rel=preload; as=script, </50c25a04-a68e3217d6ce65727bd7.js>; rel=preload; as=script, </c0d53ec4-df4e584640768dd709a2.js>; rel=preload; as=script, </532a2f07-f1ad28da1825cfcce2c7.js>; rel=preload; as=script, </app-c909f5221fe55e6f7849.js>; rel=preload; as=script, </c943faba-f859f80ceb7f4f7eab31.js>; rel=preload; as=script, </af13d906-36fdbc23fc7dd2f2b2e7.js>; rel=preload; as=script, </ec1189df-4ae9e03f4545d4f1d61b.js>; rel=preload; as=script, </a9a7754c-29508ff4045f1f93a5f6.js>; rel=preload; as=script, </commons-cea6bfcc846ea7ff6166.js>; rel=preload; as=script, </c974efff6ac245e04f4a26711b42db767846e0e5-b1b7091203b51af325ff.js>; rel=preload; as=script, </component—src-pages-etcher-success-banner-js-98ac1a1084e1d2a478fa.js>; rel=preload; as=script, </page-data/app-data.json>; rel=preload; as=fetch; crossorigin, </page-data/etcher/success-banner/page-data.json>; rel=preload; as=fetch; crossorigin”],“referrer-policy”:[“strict-origin-when-cross-origin”],“server”:[“Netlify”],“status”:[“200”],“strict-transport-security”:[“max-age=31536000”],“vary”:[“Accept-Encoding”],“x-content-type-options”:[“nosniff”],“x-frame-options”:[“DENY”],“x-nf-request-id”:[“01GDD0X75R40GM59JNZT3WT3GH”],“x-xss-protection”:[“1; mode=block”]},“referrer”:“”,“error”:“net::OK”},“sample”:0.1,“applicationSessionUuid”:“973581f0-ebdb-4016-8abe-b4c97aac4edc”,“flashingWorkflowUuid”:“60dcac6c-0622-4f3d-8729-284d47ac8302”})
